Reply
Thread Tools Display Modes
Old 10th of September 2003 (Wed)   #1
leungivan
Default G3 with 540 EZ
I known from user guide that G3 should work with 550 EX. But I only got 540 EZ in hand. When I took photo with the flash, it is too bright. Is it because failed to use TTL ? Should I use manual to set the power of the flash ?
Thanks a lot.
leungivan is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
540 EZ Manual Murphy66 Small Flash and Studio Lighting 6 1st of December 2005 (Thu) 13:08
$540,000 Whaler The POTN Lounge 3 25th of September 2004 (Sat) 03:00
540 EZ and the D60 GenEOS Canon EOS Digital Cameras 2 10th of April 2003 (Thu) 12:42
