Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The Business of Photography
Reply
Thread Tools Display Modes
Old 8th of May 2006 (Mon)   #1
ghosh
ghosh's Avatar
Default Pic quality
Dear friends
Recently I was asked by a painter to photograph his paintings for copy right purpose. I took all the pics in negative ISO 100. When I developed the photographs I found that all the pics had a different color, though it is some thing that is not visible easily. But some one who is good at recognizing color will find out quickly. Can any one tell me what could have been the "X" factor?
I took all the pics in F5.6 and at 1/60.
I also have one more question
Can a higher F number such as f11 would produce better color in this case as well as in other cases.
#include <iostream>
int main() {
std::cout << "POTN is the best." << std::endl;
return 0; }
ghosh is offline   Reply With Quote
Old 8th of May 2006 (Mon)   #2
Longwatcher
obsolete as of this post
Longwatcher's Avatar
Default Re: Pic quality
I would have to suspect the reason for the difference in color is the spectral response of the film (or development process) verus the spectral response of human eyes. Meaning the film sees something different then people will.
Also changing f-stop on lens is unlikely to affect color (at least in the manner you need). However a different lens might provide better (or worse) color as some are coated to provide a more accurate color response.
Also the light itself (especially if using artificial light) will affect the final color of the shot, even if it looks correct to your eye.
Lastly I presume you were shooting film. If shooting digital then the sensor will also have an effect on the colors. As some one once said, buying a digital camera is buying into a permanent roll of a specific film type.
Hopes that helps a little bit,
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher.com/photoequipment.htm
Longwatcher is offline   Reply With Quote
Old 9th of May 2006 (Tue)   #3
PhotosGuy
Moderator
PhotosGuy's Avatar
+ the different spectral response of the pigments used. Maybe + the dufus in the lab who's making the prints?
Film/digital? Lighting setup? Example of the images?
Lots of threads here on copying paintings, but search results don't have a long shelf life, so it's better if you do it yourself.
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Old 9th of May 2006 (Tue)   #4
chtgrubbs
If your lighting and exposure are consistent, the the problem is with your color printer. When negatives are run through a printing machine the color balance of the negative is scanned by the machine and adjusted automatically, so subjects of varying color balance and composition will cause the machine to adjust the color balance to try to make the overall print. When I shoot items that need consisten color balance, I put a gray card in the first frame and tell the printer to balance on the gray card and print the entire roll with that color balance.
chtgrubbs is offline   Reply With Quote
Old 9th of May 2006 (Tue)   #5
ghosh
ghosh's Avatar
Thanks every one. I think the problem should have been with the printing person.
#include <iostream>
int main() {
return 0; }
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Pic quality of SD800/IXUS 850 slicendice Small Compact Digitals by Canon 8 15th of July 2007 (Sun) 11:51
Pic Quality Q.... ItsMike Canon EOS Digital Cameras 5 16th of May 2007 (Wed) 09:39
pic quality??? bmac Canon G-series Digital Cameras 6 22nd of April 2003 (Tue) 15:02
Newbie & S30 Pic quality bluegsr Small Compact Digitals by Canon 1 18th of April 2003 (Fri) 01:40
Best quality pic from s200? ke104 Small Compact Digitals by Canon 3 28th of March 2003 (Fri) 23:25
