Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 8th of May 2006 (Mon)   #1
RichAK
Question Long distance shooting
I was out in Denali National Park and traveled in on the road about 30 miles. (they opened up 15 additional miles prior to May 20th when the buses start running) Spotted a big grizzly across the river (estimated about 1/2 mile away) Set up camera (20D), tripod, and Sigma 50-500mm. The lense pulled him in so that he was recognizable in the viewfinder but the shots did not come out sharp (shot auto, AV, TV, manual focus, different ISOs, AWB plus selected AWBs, timer, just about every combo there was). He was a very cooperative bear and moved slowly. I've focus tested the lens and it focuses fine. I've shot wildlife closer than this and they've come up razor sharp.
My question is, "Am I expecting too much from this lens."? "Is there a certain range (distance) that lenses are effective in or do I still need a lot more practice?"
Rich
Canon 20D, EF 17-40L, EF 70-200L f4.0, EF 28-135 IS, 50 F1.8, 2X tele, bogen/manfrotto tripod
RichAK is offline   Reply With Quote
Old 8th of May 2006 (Mon)   #2
spaced
spaced's Avatar
Default Re: Long distance shooting
What shutter was used matey?
Never delete a photo.
http://www.photoboxgallery.com/macfadyen
All proceeds go to Cancer Research UK.
spaced is offline   Reply With Quote
Old 8th of May 2006 (Mon)   #3
RichAK
I had a variety of shutter speeds. They ranged anywhere from 1/125 to 1/2000. Some additional info: The river was frozen with snow on top (I did use just a touch of comp 1/3 up and down), weather was partly cloudy (some sun), 45 degrees fahrenheit. Bear was either standing on the white snow (brown bear) or on the gray gravel for the shots.
Rich
Old 8th of May 2006 (Mon)   #4
stupot
bear (hehe no pun intended...) in mind how far away it... its probably due to atmosphere and not the lens.
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
stupot is offline   Reply With Quote
Old 8th of May 2006 (Mon)   #5
spaced
spaced's Avatar
I sometimes 'forget' the 1/focal length rule when i'm popping off shots. do you think you did this? as 1/125 at 500m would produce quite blurry images even in a tripod, possibly from pressing the shutter.
Did you try some partial spot metering?
Old 9th of May 2006 (Tue)   #6
Skeeter4
Wink Re: Long distance shooting
I told you, you gotta bring them bears in closer. Even that Bigma isn't gonna give you a good picture of a bear a mile away. Ya gotta strip down naked, cover yourself in bacon and start thrashing around in the brush like a wounded moose. The bears will come so close you can shoot them with that 17-40 you got.
I tell you what. Just drop that Bigma off at my house and I'll test it out for you. I should have it back to ya before the first good snowfall.
Oh, and to answer your question. Yes, you do need allot more practice.
Skeeter4 is offline   Reply With Quote
Old 9th of May 2006 (Tue)   #7
weka2000
Is that a 300mm in your pocket?
weka2000's Avatar
Thats the best Ive ever heard on how to get closer shots, and how to get a bigma.
Thats a fair distance your shooting at. What was the focus mode set to. If you shoot in raw have a look with in the software. I know when I had my 20D the software from canon showed you in red what the focus points were.
Post a couple of shots.
weka2000 is online now   Reply With Quote
Old 9th of May 2006 (Tue)   #8
RichAK
I had it set on evaluative metering where it averages for the whole scene (camera default). Maybe I need to get it on partial or centerweight But you know I had shutter speeds ranging up to about 1/2000 so I would think camera shake (even on the tripod) wouldn't affect it at this shutter speed.
Rich
Old 9th of May 2006 (Tue)   #9
RichAK
Yeah, Skeeter and I shoot together sometimes. He gets some outstanding stuff but I'm thinking he has lens envy and needs to get that 600mm prime he's been talking about. He's a telephoto addict and won't be satisfied until he can figure out a way to mount the Hubble telescope on the front of his 5D.
Thanks for that reminder on the Canon software I forgot all about that one. I have it and I'll reinstall it and check it out. Need to resize the shots and I'll post them shortly.
Rich
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
couple of long distance receivers racketman Macro 7 22nd of April 2007 (Sun) 01:45
Long Distance Casting tj289 Sports 21 17th of March 2007 (Sat) 18:50
Long Distance Shooting Part 2 RichAK General Photography Talk 7 12th of May 2006 (Fri) 22:18
Best lens for long long distance ladybelle2k Canon EF and EF-S Lenses 18 6th of April 2006 (Thu) 20:53
Long distance telephoto pwagner Canon EOS Digital Cameras 2 5th of August 2003 (Tue) 09:09
