Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 9th of May 2006 (Tue)   #1
jwkramer
Question ACR 3.4 - Am I missing something?
I've been playing around with Adobe CS2, and ACR 3.4 and it seems to me that Adobe missed the boat somewhat with regards to the 30D controls. I can't find access to the "Picture Style" controls in the interface anywhere. It looks like basically the same old controls that were there before (for all the other camera models). While I was experimenting, I found that Breeze Browser allows access to these controls in their interface, so I know it's just a matter of accessing them.
For me, I find that shooting all images in RAW and then playing around with the "Picture Style" in post processing is a much preferred method to picking one before shooting. Why lock yourself into shooting a scene in B&W with a red filter (for example) at the time of capture when it's just as easy to see what the image would look like if you would have shot it that way during post processing instead. It's almost like being able to shoot with multiple "films" at the same time.
If I'm missing something, please enlighten me...
jwkramer is offline   Reply With Quote
Old 9th of May 2006 (Tue)   #2
EOSAddict
Book Committee Immortal
EOSAddict's Avatar
Default Re: ACR 3.4 - Am I missing something?
I don't think adobe has picture styles for the 5D either. I assume its 'proprietary' Canon stuff only accessible thru DPP.
Al
My Gear, My Website: www.e-ScapePhotography.co.uk
EOSAddict is offline   Reply With Quote
Old 9th of May 2006 (Tue)   #3
jwkramer
it can't be too proprietary... Breeze Browser figured out how to do it. The only thing with Breeze Browser is that if you choose to edit the image instead of convert it, it uses the ACR to convert the RAW image instead of the built in tools in Breeze Browser. I can't help but think this is more of a case of laziness on the part of Adobe. It was probably a lot easier to just add a couple of new models to ACR than actually write new code... <roll eyes>
Old 9th of May 2006 (Tue)   #4
Lester Wareham
Moderator
Lester Wareham's Avatar
All the picture styles must be are settings for saturation and contrast, perhaps via curves. So it would be fairly easy to setup ACR templates for those if you knew the settings, the settings I guess are Canon proprietry but perhaps the Breeze Browser folk reverse engineered it. I guess the easy way to do that would be to look at the settings DPP uses for the various styles.
My Photography Home Page RSS Feed
MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair!
Macrophotography by LordV
Lester Wareham is offline   Reply With Quote
Old 9th of May 2006 (Tue)   #5
jwkramer
perhaps. It makes the interface very user friendly - check it out:
http://www.jim-kramer.com/photos/BB-IF.jpg
I guess the proof would be to let the camera shoot a few in different styles, and then compare that to what you get in post processing using the "reverse engineered" versions in BB.
Old 9th of May 2006 (Tue)   #6
PacAce
Moderator
PacAce's Avatar
The picture style is just a setting in the EXIF info which tells the Canon raw converter what defaults to use when initially converting the raw image. And, of course, you can change the setting from what you initially had the camera set to.
Third party raw converter programs that use their own algorithm for converting the raw image know nothing about the Canon picture styles and just ignore it.
There are, however, third party raw converter programs that make use of Canon's raw converter API (application programming interfaces) to convert the raw image. And Breeze Browser is one of those companies that also use the Canon APIs. That's the reason they can also process picture styles.
...Leo
PacAce is offline   Reply With Quote
Old 9th of May 2006 (Tue)   #7
gkas
BreezeBrowser knows how to use it because Breezebrowser uses the Canon SDK (Software Development Kit) to reproduce all of the functions. ACR is proprietary software that replicates the functions, some of which it has chosen not to replicate.
Gerry Kaslowski
gkas@socal.rr.com
Gerry's Pics http://MikeKazPhotography.com/Gerry/
gkas is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ACR Calibrator & ACR 3.1 Dale RAW, Post Processing and Printing 7 3rd of August 2008 (Sun) 09:12
ACR 4.1 - missing B&W checkbox... tim RAW, Post Processing and Printing 4 8th of June 2007 (Fri) 08:48
New ACR - v3.6 Double Negative RAW, Post Processing and Printing 2 2nd of November 2006 (Thu) 12:42
ACR ?? nanko RAW, Post Processing and Printing 3 13th of September 2006 (Wed) 17:00
Anyone here use the Fors ACR Script and Gretag color card to calibrate ACR? col4bin RAW, Post Processing and Printing 10 7th of July 2006 (Fri) 05:49
