Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 10th of May 2006 (Wed)   #1
IanD
Honorary Moderator
IanD's Avatar
Default Camera/Tripod Vibrations.
The attatched article, posted with the permission of Markins America (http://www.markinsamerica.com/MA5/index.php) is a report on Vibrations in Photography Equipment. I discovered it while doing some research into a new top plate for my Gitzo 1327. Steve Yoon, of Markins USA, has kindly allowed me to post his research article. There is a lot of technical information contain in it and rather long, but the facts it reveals are very interesting.
I am in no way connected with or compensated by Markins America.
Vibration Report.pdf
Ian (Duck Photographer)
Have You Hugged Your Mallard Today?
More Images- My Gear
New Image Posting Rules (please read)
IanD is offline   Reply With Quote
Old 26th of June 2006 (Mon)   #2
rhys
Dis-Membered
rhys's Avatar
Default Re: Camera/Tripod Vibrations.
Interesting... The link above the box worked and gave me a good PDF file. The link in the box gave me a corrupt PDF.
Rhys
The empire conquers yet more galaxies:
www.sageworld.co.uk
www.sageworld.org
www.sagephotoworld.com
Blog: http://360.yahoo.com/thunderintheheavens
Free cheese comes only in mousetraps
rhys is offline   Reply With Quote
Old 14th of September 2006 (Thu)   #3
Ken Fong
I had a sturdy tripod but was on a wooden platform, so I was concerned about vibration caused by the mirror of the RZ67 I was using. The mirror lockup was easy to learn and use...I am now considering to use it on the 20D in similar situations.
Ken Fong is offline   Reply With Quote
Old 19th of September 2006 (Tue)   #4
iain1969
iain1969's Avatar
I have just hooked up a Gitzo 1258 with the Markins ballhead - seems to be solid as a rock so far !
Iain
30D, 50 f/1.4, 10-22, 24-105L, 70-200 f/4L, 100-400L
Gitzo 1258, Markins Q-Ball M20L
iain1969 is offline   Reply With Quote
Old 20th of September 2006 (Wed)   #5
GilesGuthrie
GilesGuthrie's Avatar
I wish I'd known about and understood Mirror Lock Up (MLU) years ago. Previously I'd thought that I just needed a more expensive tripod, but it's saving me the expense.
Gallery - Fantasy F1 2009 - Forums - Reviews - Twitterings
Canon EOS 1d MkIII, 5d. Gear List
GilesGuthrie is offline   Reply With Quote
Old 9th of October 2006 (Mon)   #6
gubak1
User is banned from forums
This report is very interesting!
gubak1 is offline   Reply With Quote
Old 9th of November 2006 (Thu)   #7
KCMO Al
but rather painful to read since it was obviously written by a non-native English speaker.
Film: Leica M-4, Elan 7E, Rolleiflex 2.8f, Pentax 645 -- Digital: Canon Pro-1, EOS 5D
EOS Lenses: Sigma 24-70 f2.8 EX - Canon EF 17-40 f4.0L - Canon EF 24-105 f4.0L - Canon EF 35 f1.4L USM - Canon EF100-400 f4.5-5.6L IS USM - Canon EF100 f2.8 Macro - Other stuff: MR 14EX - 430EX - 580EXII - ST-E2 - TC1.4x - TC-80N3
KCMO Al is offline   Reply With Quote
Old 31st of January 2007 (Wed)   #8
devil350
devil350's Avatar
The article you posted is very interesting thanks for you share.
Laurent.
MY Gear List | My Gallery
devil350 is offline   Reply With Quote
Old 6th of March 2007 (Tue)   #9
labbai
labbai's Avatar
Cool Re: Camera/Tripod Vibrations.
Most of this tripod vibrations talk is idle... if you got a stable tripod, it doesen't vibrate but in your dreams.... wooden tripods absorb vibrations rocks vibrate when the globe rotates... nothing is stable, so you'll have to get a tripod solid as a rock (sic!), wich doesent mean a thing.... you can't get a sharp picture anyways... With a stable tripod you may try. I shoot most of my pics handheld. I have a "solid as a rock" tripod also...when needed.
Canon, Gitzo, RRS, Zeiss, Peleng
labbai is offline   Reply With Quote
Old 12th of January 2008 (Sat)   #10
jhom
jhom's Avatar
The Markins vibration study is very interesting and helps highlight important factors in our setups. However, in reading the study I noticed some problems in the comparisons among tripods and heads. Most importantly, several important variables were not held constant making the statements regarding comparisons among items rather tentative. For example, the comparision between the Gitzo 1227 and Manfrotto 055 tripods is based on a carbon fiber tripod and an aluminum one. So the conclusions regarding stability of one over the other are somewhat misleading.
Regardless, the study is quite informative. There are very few available resources such as this on the web for everyone to review.
Jim
jhom is offline   Reply With Quote
Old 12th of January 2008 (Sat)   #11
pturton
I have an aluminium legset that easily supports my weight (I tried it- 220 lbs.) without collasping, slipping or buckling but that legset takes significantly longer to stop 'ringing' than my GT2530 CF tripod that is only rated at 26 lbs. (I've tested my GT2530 to 86 lbs.) By 'ringing' I mean snapping a finger or other object against a leg while feeling the head for vibrations.
Just laying a small grain bag against the leg of this aluminium legset makes it almost as vibration dampenedd as the Gitzo CF without any dampening.
pturton is offline   Reply With Quote
Old 10th of April 2008 (Thu)   #12
fyz
Hi,
Maybe you can try Advanced PDF Repair at http://www.datanumen.com/apdfr/ This tool is rather useful in salvaging damaged PDF documents.
Hope this helps.
Alan
fyz is offline   Reply With Quote
Old 10th of April 2008 (Thu)   #13
chauncey
chauncey's Avatar
That treatise was one of many that I read in my upgrade research. Finally decided on a Merkins 20 atop a Dutch P900 tripod.
chauncey is offline   Reply With Quote
Old 10th of April 2008 (Thu)   #14
Jannie
Jannie's Avatar
I sure wish my 5D had an external one step MLU, if I'm on a tripod I almost always use MLU with my longer lens/w/tele-extender. It's just such a hassle going through the menu.
Ms.Jannie
"When you come to a fork in the road, take it"!
1DMKIII, 85LII, 24-70L, 100-400L
Jannie is offline   Reply With Quote
Old 15th of July 2008 (Tue)   #15
ben_r_
-POTN's Three legged Support-
ben_r_'s Avatar
I was just referred to read this and am very impressed! Not all the way finished with it but wow I had no idea how much had been taken into account with tripod support!
ben_r_ is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Looking for a tripod and camera bag felipemia89 Accessories & Storage 5 3rd of June 2007 (Sun) 23:22
ultra-sonic frequency vibrations??? zach Canon EF and EF-S Lenses 11 8th of February 2007 (Thu) 00:27
WTB: (CAN) 430EX, Camera Bag/Backpack, Travel Tripod,Tripod,Sigma 70-300APO Canon JaGWiRE Classifieds: Buy 0 13th of September 2006 (Wed) 22:31
Is cold weather bad for our cameras ? vibrations ? The22oz The POTN Lounge 1 9th of February 2006 (Thu) 17:45
Camera on tripod kram Accessories & Storage 5 20th of June 2005 (Mon) 01:45
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
