Reply
Thread Tools Display Modes
Old 14th of September 2003 (Sun)   #1
dkwelk
Default TC-DC52 light loss?
Hi:
'Was curious if anyone with a TC-DC52 or other PowerShot A-series teleconverter has noticed light loss. A 2.4X teleconverter on a standard SLR reduces aperture by an f-stop or more. You can't really afford that when the f-equivalent on the A70 at max focal length is already a sluggish f4.8
dkwelk is offline   Reply With Quote
Old 14th of September 2003 (Sun)   #2
bfaust
Default Re: TC-DC52 light loss?
I don't think the G2 teleconveeter loses light because it is being added in front of the lens. The SLR teleconverter loses light because it is behind the lens. Some smart guy can give us the physics behind all that.
bfaust is offline   Reply With Quote
Old 17th of September 2003 (Wed)   #3
dkwelk
Hi:
I did a bit of research since this posting and came upon this explanation for light loss when using a teleconverter with a standard SLR: the loss results from the converter extending the aperture further away from the film plane (so it's smaller in relation to it). That wouldn't happen with a front mounted converter like the TC-DC52. I'm going shopping.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
DIY softbox question - light loss? yunaiseng Small Flash and Studio Lighting 11 20th of June 2007 (Wed) 23:05
Light loss using a TC sagebrush Canon EOS Digital Cameras 7 12th of January 2007 (Fri) 08:12
Light loss with Extension tubes?? canonshooter4life Canon EF and EF-S Lenses 7 6th of January 2007 (Sat) 06:35
Light loss with extensin tubes Blue Deuce Macro 2 4th of December 2006 (Mon) 08:16
Light loss per lens jojohohanon Canon EF and EF-S Lenses 25 30th of January 2006 (Mon) 16:20
