Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 17th of May 2006 (Wed)   #1
Amorous
Default Tips to shoot airshow
I'm planning to shoot an airshow this weekend. Any tip is appreciated. I have a 20D and Sigma 70-200, plus 1.4x and 2x TC's. Will it be long enough or do I really need super-tele lens?
My web site: http://kaitcilla.smugmug.com/
Los Angeles area local photography group: http://lashooters.org
Amorous is offline   Reply With Quote
Old 17th of May 2006 (Wed)   #2
etaf
etaf's Avatar
Default Re: Tips to shoot airshow
i have used a 200mm on a normal film camera - so you should have plenty of mm there - you have 200 with a 2x = 400mm and then crop factor of 1.6 = 640mm - thats loads of mm
the only tips i would suggest are.
1) I when shooting into the sky you will get an inaccurate exposure reading from the camera, a technique used was a) meter off some grass or concrete in the same direction as you will be taking the shot b) meter off my hand or c) use spot metering and try to meter off the plane.
2) keep your shutter speed high to avoid camera shake - remember an old rule of thumb 1/effective focal length - so if you are using your 200mm end of the lens then that is 1/1.6 x 200 = 320 so use a shutter speed greater than 1/320.
3) the last air show i was at a guy near to me had a radio which picked up the transmissions between the pilots etc - i heard the command break and then the formation broke which made timing great... no idea what he was using though and by the time i made a move to speak to him he was gone.
4) take plenty of CF cards or use a portable storage to store pictures - i have 3 CF cards 1 1GB and 2 512MB and then I have one copying into an image tank - one loaded and one spare
5) do you have any wide angle lens - there may be a few planes on the ground and you may find 70mm too long - just read your sig so ignore
good luck - but also enjoy the show
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
etaf is offline   Reply With Quote
Old 17th of May 2006 (Wed)   #3
::John::
Thanks for asking, Amorous
I am looking forward to an airshow in June and the reply ETAF has provided is great.
Thanks, ETAF
::John:: is offline   Reply With Quote
Old 17th of May 2006 (Wed)   #4
tiktaalik
tiktaalik's Avatar
Use fast shutter speeds (1/1000s) for jets to stop the motion but slow down the shutter speed for prop planes and helicopters in order to get prop blur. This is a constant battle with trying to keep the shutter speed high to avoid blur from handholding long telephotos, but try to go no faster than 1/250s or 1/200s for prop planes. Helicopters may need even slower shutter speeds.
Julie
Julie
My galleries
tiktaalik is offline   Reply With Quote
Old 17th of May 2006 (Wed)   #5
Orgnoi1
Orgnoi1's Avatar
You should do plenty fine with the equipment you have... the most used lens for aviation is the 100-400L and you will have even better aperatures with your 70-200 with the 1.4x... like was said above try to keep any propped planes at lower than a 1/250th and you will get nice motion... helos require a LOT lower speed to get a full circle motion... get there early and get good seating... if you can get there for a practice day then thats the key to getting most of the real good shots when no one is there getting in the way...
TRJ Photography - Canon CPS Member
Berkshire Scenic Railway Museum Staff Photographer
Visable and IR Photography / Canon , Mamiya , Toyo
Are you a photographer in the Northeastern USA? Come visit us! (Click Here)
Orgnoi1 is offline   Reply With Quote
Old 17th of May 2006 (Wed)   #6
::John::
I hope Amorous is going to enjoy all this info - I know I am. Thanks, peeps.
Julie - I have seen your aircraft pics - excellent stuff!
Old 17th of May 2006 (Wed)   #7
etaf
etaf's Avatar
a monopod may be ueful - i have one now, but never used for an airshow
Old 17th of May 2006 (Wed)   #8
Orgnoi1
Orgnoi1's Avatar
Be REAL careful if you choose to use a monopod... you are going to end up hitting a lot of people in front of you when the planes head skyward...LOL
Old 17th of May 2006 (Wed)   #9
PhotosGuy
Moderator
PhotosGuy's Avatar
Sports Shooting Tutorials and Advice
http://photography-on-the.net/forum/...d.php?t=135417
AF Point selection for sports
http://photography-on-the.net/forum/...d.php?t=112654
Air Show Photography
http://photo.net/learn/airshow/
Why do you guys use manual? AV makes more sense.
http://www.photography-on-the.net/fo...d.php?t=130176
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 17th of May 2006 (Wed)   #10
adamsti
adamsti's Avatar
Monopods are really only good for engine run up, or taxi shots where you want a lot of prop blur, like this. I think this is 1/60 or a little lower. Gets tough to hold it steady when you get this slow. As said above if you use it for fly overs you will nail somebody with it.
7D, 5D MKIII, 17-40 f/4L, 24-70 f/2.8L, 70-200 f/2.8L IS, 300 f/2.8L IS, 500 f/4L IS, 1.4xII, 2.0xII
"I love the smell of racing gas in the morning"
http://www.timadamsphotography.com
adamsti is offline   Reply With Quote
Old 17th of May 2006 (Wed)   #11
Amorous
Thank you all for very good tips. I'll keep it in mind when I shoot.
One more question. When I do aerial shots, do I lie down on the ground (of course facing up) or just wait until the plane gets at an angle? I'm worried about getting a neck pain. LOL
Old 17th of May 2006 (Wed)   #12
Amorous
Wow. This is a fantastic shot. For this kind of shot, I think I'll use my 24-105 since it has the IS. It seems like you were right in front of the plane. Were you allowed to do that? Obviously you did.
Old 17th of May 2006 (Wed)   #13
adamsti
adamsti's Avatar
I don't have the EIXF data handy, but this was with the 70-200, I think. It is at the fence, in the pits at Reno. You can zoom is pretty tight. They are probably 25-30yds away.
Old 17th of May 2006 (Wed)   #14
etaf
etaf's Avatar
if you install opanda for IE or firefox whatever you use you can right click on the image and see the EXIF as its beem loaded with the image
www.opanda.com
great little add-in
taken on a 10D
at 1/60th
F20
ISO100
250mm so that must be the 35mm equiv if taken with your 200mm
Old 17th of May 2006 (Wed)   #15
adamsti
adamsti's Avatar
www.opanda.com
great little add-in
taken on a 10D
at 1/60th
F20
ISO100
Thanks, I can't install that at work, Big Brother watching. If it was 250mm then I was using the 100-400L.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Airshow lens tips... 3Turner Transportation 15 4th of November 2006 (Sat) 19:04
Can I get some tips for shooting an airshow? TMR Design Small Compact Digitals by Canon 5 24th of August 2006 (Thu) 17:20
Tips for airshow pics appreciated... emtp563 The Business of Photography 9 29th of June 2006 (Thu) 23:24
Airshow Shooting Tips socalibordr Transportation Talk 20 21st of October 2005 (Fri) 01:25
Tips on shooting @ the Airshow Tyger General Photography Talk 2 2nd of September 2005 (Fri) 17:42
