Reply
Thread Tools Display Modes
Old 16th of September 2003 (Tue)   #1
wenzej
Default Difference between Super Fine and Fine
I know what this does; Super fine is less compression then Fine and that Super fine is better because it looses less picture information. However it takes up twice the space.
I want to see if it makes any difference in the picture, so I thought I would shoot the same picture in Super Fine and Fine and compare them. I expect them to be very close, but I have no idea what to look for. Should I look for loss of fine detail or color shifts or what?
Also does it take longer to compress the picture more and save it to the card or does it take longer to save the larger file? What I wonder is would it cause a delay when taking pictures quickly?
wenzej is offline   Reply With Quote
Old 17th of September 2003 (Wed)   #2
jyrgen
jyrgen's Avatar
Default Re: Difference between Super Fine and Fine
1. You could put them on layers in your photo editing software and use a layer blending mode that shows the difference between the two layers. I don't know which mode, but there certainly is one. It might be helpful or at least interesting
2. I'm sure it takes longer to save the larger file. The Digic processor that does the compression among other things is pretty fast. You can verify this by thinking of or looking at the continuous shooting mode - you are limited rather by the speed the images are saved from the buffer to CF than by processing speed. Use the smallest format and worst quality jpeg and you can take lot more continuous pics, although they need more processing.
Canon 35/1.4 | Canon 50/1.4 | Canon 135/2 | Canon 17-40/4 | Canon 24-105/4 | Canon 70-300/4.5-5.6
Canon 5D | Canon Speedlite 430EX | Manfrotto 055 ProB + 488RC2 | Kenko ext tubes & 1.4x TC
jyrgen is offline   Reply With Quote
Old 18th of September 2003 (Thu)   #3
John from PA
In general shoot in the highest possible resolution you can get. Then later if you get that exceptional shot that you need to crop you might be able to do so without any major ramifications.
Also, don't repeatedly save an image as you work with it in software. I think a lot of people do this (habit from things like MS Word or Excel) but each time you do a "Save" the compression goes up and the image quality goes down. At a recent digital photograpy school I attended the instructor took a beautiful picture of one of the state quarters and then saved it 6 times. After the 6th save you couldn't teel it was a quarter.
John from PA is offline   Reply With Quote
Old 18th of September 2003 (Thu)   #4
dtrayers
dtrayers's Avatar
Here is a comparison of the Superfine vs. Fine modes for the G3:
http://www.dpreview.com/reviews/canong3/page12.asp
You can click on the images to download the full size versions and compare them for yourself.
-Dave
http://www.trayersphotography.com
dtrayers is offline   Reply With Quote
Old 18th of September 2003 (Thu)   #5
Shaner (Ut)
Question for John
When ya say don't repeatably save it, are you refering to saving while you're in the process of working on it without closing, or are you talking about opening the file, work on it, save it and close it, then repeat?
The small town I live in is famous for power bumps. There has been many times I have been in the middle of editing a pic and the power will go out so I started to save my work as I edited the photo.
I will make several adjustments and then save and keep editing but never close out the image (unless the power went out) until I'm done.
Shaner (Ut) is offline   Reply With Quote
Old 18th of September 2003 (Thu)   #6
dtrayers
dtrayers's Avatar
What John means is saving it in a lossy format like JPG.
Every time you save, the computer has to compress the picture, and it throws away some information. Do that too many times and you'll begin to see the degradation.
However, I think that if you have some kind of background save turned on, it's just saving and overwriting images, so you won't begin degrading until you re-open a saved image.
If you do need to make frequent saves, make sure it's in a non-lossy format, like a TIFF or, if you are using Photoshop, in it's native PSD format.
-Dave
Old 19th of September 2003 (Fri)   #7
hypokondriak
The default windows jpeg viewing software that comes with windows is notorious for losing quality of shots. I used to rotate my pics with this - then I started watching file sizes.
Personally, I would only shoot SuperFine if I was shooting in that mode - that way you always have the highest quality pic for your archives... my anal .02 tho.
hypokondriak is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fine, Super Fine, Normal Pretty3Horses Small Compact Digitals by Canon 18 20th of July 2006 (Thu) 10:20
What is the difference between Fine and SuperFine mode? TMR Design Small Compact Digitals by Canon 1 20th of February 2006 (Mon) 17:30
Fine, Super Fine, Normal Cadenza Canon G-series Digital Cameras 3 6th of September 2003 (Sat) 05:55
Normal, Fine or Super Fine? ALLTHUMBS Canon G-series Digital Cameras 1 26th of June 2001 (Tue) 23:38
