Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 18th of May 2006 (Thu)   #1
chansh
chansh's Avatar
Default HDR manualy done -no photomatix, no Merge to HDR
Had a play around with CS2's "Merge to HDR" but the results were very disappointing. There were no contract, lost of details and the colours were horrid.
SO, I did it myself.
Tell me what you think.
Saigh H Chan
40D, 350D
, Canon 70-200L f2.8 IS USM, Canon 70-300mm DO IS USM, Tamron 28-75mm f/2.8 XR Di, Tokina 12-24 AT-X124 PRO DX. Sigma EF-500 DG SUPER.
chansh is offline   Reply With Quote
Old 18th of May 2006 (Thu)   #2
MJCfromCT
MJCfromCT's Avatar
Default Re: HDR manualy done -no photomatix, no Merge to HDR
Looks quite nice indeed. Care to share your secret?
60D | BG-E9 | 430EX | Sigma 17-50mm | Canon 100-400mm L | Canon 50mm f/1.8
MJCfromCT is offline   Reply With Quote
Old 18th of May 2006 (Thu)   #3
JMAS
JMAS's Avatar
Yes please!
You've got some awesome results.
I've played a bit with HDR on CS2 and found the results and control over them were a bit disapointing. Haven't tried Photomatrix though.
Cheers,
Jaime
______
Gear
Some photos
JMAS is offline   Reply With Quote
Old 18th of May 2006 (Thu)   #4
chansh
chansh's Avatar
Both of the pics was a 3 image merge. Using the video here.
Saigh H Chan
40D, 350D
Old 18th of May 2006 (Thu)   #5
JD.
JD.'s Avatar
Top one looks like a drastic overuse of something in the sky... perhaps Shadow/Highlights?
http://www.sbsessions.com
http://www.photographyjd.com
Canon 20D
Canon 400mm 2.8
A Dozen Other Lenses
Underwater Housing
Misc Paraphernalia
JD. is offline   Reply With Quote
Old 18th of May 2006 (Thu)   #6
Duder
Duder's Avatar
these are nothing to do with HDR.
HDR's are 32-bit images, which in order to view on a computer monitor require a tone-mapping conversion to 16 or 8 bit.
Extending the dynamic range of an image using exposure blend, or using shadow/highlight aggressively produces an IDR (increased dynamic range), not an HDR.
Pete
http://www.pbase.com/petejackson
Duder is offline   Reply With Quote
Old 19th of May 2006 (Fri)   #7
chansh
chansh's Avatar
I do have those pics as 32-bit images. Therfore they are HDR. I just had to save them as jpegs to display them here.
Saigh H Chan
40D, 350D
Old 19th of May 2006 (Fri)   #8
Samiad
Samiad's Avatar
Now we're comparing increased dynamic range and high dynamic range....we should be politicians...
Digital Photography
http://www.samiad.co.uk/gallery
Samiad is offline   Reply With Quote
Old 19th of May 2006 (Fri)   #9
Duder
Duder's Avatar
as far as I'm aware it's impossible to create a 32-bit image manually.
how did you merge them to make a 32-bit image?
I ain't making this up. There are specific definitions for different processes, and there seems to be a bit of confusion over what constitutes actual HDR's compared to alternative techniques.
Pete
Old 19th of May 2006 (Fri)   #10
StealthLude
StealthLude's Avatar
I watched the video, and you are wrong.
The above are NOT HDR, they are just "more dynamic range"...
It looks good, dont get me wrong, but it aint HDR. You cant tone map or or merge to HDR and get the same results. I can tell the difference beteween TRUE HDR and homebrew.
Try photomatrix, its a totally different ball game.
[[Gear List]]
Skype: Stealthlude
StealthLude is offline   Reply With Quote
Old 19th of May 2006 (Fri)   #11
StealthLude
Also, if you look at the shadows in the windows, there is no dynamic range to them...
And just becaues you have a 32 bit file, does not mean you have HDR. My HDRs arnt even that great, im still learning, but there is a lot of science behind one of them.
[[Gear List]]
Skype: Stealthlude
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What do you guys think of Photomatix / HDR? hegemon RAW, Post Processing and Printing 72 10th of August 2007 (Fri) 12:10
Merge to HDR? Travis F RAW, Post Processing and Printing 14 9th of November 2006 (Thu) 10:14
HDR - Photomatix problem EOS mE RAW, Post Processing and Printing 6 19th of August 2006 (Sat) 22:08
Photomatix or CS2 HDR? SWPhotoImaging RAW, Post Processing and Printing 1 16th of May 2006 (Tue) 12:33
Merge To HDR drisley RAW, Post Processing and Printing 3 21st of April 2006 (Fri) 17:52
