#1 |
I just bought an optical trigger to use with a 420EZ flash. It will fire once properly if I fire a flash with my 550EX. After that, though,it does not fire again unless I turn the flash off or take the trigger off and put it back on. Am I missing something? I have tried all the setting I know (full manual) etc. Is this how they are supposed to function?
| sponsored links |
#2 |
Moderator
Nope, you're not missing anything. Evidently, the Canon Speedlite flashes have some current flowing through the hotshoe after it's been fired. Other flashes that work fine with optical triggering units do, too, but the current flowing through those is not as high as that of the Speedlites. The characteristic of an SCR (Silicon Controlled Rectifier, which is the component in the trigger unit that basically acts as an electronic switch turned on optically) is that once it is triggered, it will stay turned on for as long as the minimum holding current required to keep the SCR turned on is flowing through it. So, the net effect of the higher current flowing through the Speedlite hotshoe is that the SCR does not turn off. If it doesn't turn off, then you can't trigger it again to fire the flash until you disconnect and then reconnect the flash or turn off the flash and then turn it back on again.
I just spent an hour and half this afternoon with my Speedlite connected to my home made optical trigger with a digital multimeter connected across the sync wire and ground (to mearure voltage) and an analog VOM connected in series with the sync wire (to measure the current through the sync wire). That's how I came up with the above observation.
..Leo |
#3 |
wow, thanks. I guess all optical triggers won't work then. I was going to try one of the more costly ones (i have a$14 ebay one). Which is a shame as I think that was the only peice of the puzzle keeping me from going pro
| sponsored links |
#4 |
Master Flasher
ahmadof,
See if you can pickup an old flash unit at a camera shop, pawn shop or wherever. Better if you can get one with variable manual settings. They usually go pretty cheap and most will work fine with a slave trigger.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#5 |
I had the exact same problem with my 420 and optical triggers, fortunately I have several old flashes that will work just fine with them. Still, I wish the 420 would work, but at least thanks to PacAce's description above, now we know why they won't work more than once. That was the part that always confused me, why they would fire one time correctly, but never again unless you turned it off and then back on.
"Knowledge, Sir, Should Be Free To All" Harcourt Fenton Mudd--- I, Mudd |
#6 |
Metz has an optical trigger that works.
I tried it out at my local camera store a few weeks ago and it worked perfectly. Other tests with Hama triggers didn't work. |
| Thread Tools | |
| Display Modes | |
| Optical Trigger | drisley | Small Flash and Studio Lighting | 15 | 31st of January 2006 (Tue) 00:59 |
| Homemade optical slave trigger | shakin360 | Small Flash and Studio Lighting | 16 | 12th of January 2006 (Thu) 20:44 |
| Optical trigger for studio lights | tim | Small Flash and Studio Lighting | 4 | 16th of April 2005 (Sat) 03:09 |
