Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 27th of May 2006 (Sat)   #1
Eoseni
Eoseni's Avatar
Question Help with wedding equipment
I'd appreciate your ideas on what I really need to get to round off my meager list of equipment. I'm looking to begin photographing weddings.
I know one needs back up equipment, but I'd like to round off just the "essentials" first. Granted, each person's idea of essential varies, but those of you who are already wedding pros can help educate my decisions...
Here's what I have:
Bodies: 20D, Film body Elan 7E, (but I want to shoot only digital ideally.)
Canon G2 (4MP) (Speedlite capable)
Lenses: Tamron 24-135mm 3.5-5.6 (my main lens) On 20D it's 38-216mm!
and 100mm Macro 2.8
Lights: 420EX flash; A cheap but functional 3-strobe softbox kit with optical sensors. 250W/s I think.
Other: Carbon Fiber Tripod; a Monopod; 42" 5-in-1 reflectors
As most, I'm on a tight budget, so if you can, list in order of what you would buy first, second....
Right now, my own order is:
1. 580EX, with Off camera cord 2, and a diffuser like a Lumiquest (for two light combo with my 420EX
2. A light/flash meter Sekonic L-358
3. A wide angle lens. Recommend please...the 17-55L IS sounds like a dream but is now beyond my budget I suspect
4. A battery pack CP-E3 perhaps
5. A 50mm 1.4
Thanks in advance.
Tim
Eoseni is offline   Reply With Quote
Old 27th of May 2006 (Sat)   #2
JaertX
JaertX's Avatar
Default Re: Help with wedding equipment
really, a backup body IS essential.
Even if you get something used or a recently out-of-date model. Why not that, an inexpensive zoom and another flash?
Jason - I use Canon and stuff
JaertX is offline   Reply With Quote
Old 27th of May 2006 (Sat)   #3
therosefairy
I definitely recommend a flash bracket for shooting weddings.
therosefairy is offline   Reply With Quote
Old 27th of May 2006 (Sat)   #4
liza
User is banned from forums
Get a Tamron 28-75, an extra flash, a bracket, and extra CF cards. I also recently picked up a 10D as a backup for next to nothing and prefer it in many ways to my 20D. It's slow but it produces wonderful images and is built like a tank.
liza is offline   Reply With Quote
Old 27th of May 2006 (Sat)   #5
Eoseni
Eoseni's Avatar
Anyone happy using a Light Sphere without a bracket? That seems to be it's boast.
If I do buy a bracket, any I should avoid? Better, which would you recommend? Personally I prefer simplicity and smaller rigs.
Old 27th of May 2006 (Sat)   #6
Eoseni
Eoseni's Avatar
What about the 10D do you prefer? is the shutter loud like the 20D's? It's the one complaint I have with the 20D!
Anyone esle care to help me out with my equipment buying decisions??
Old 27th of May 2006 (Sat)   #7
liza
Yes, it's a constant 2.8, and it's very sharp. I really can't tell the difference in image quality between it and my 70-200 f/4L. The 10D is a 6.3 megapixel DSLR rather than 8.2. Maybe it's just me, but it appears to produce images with more accurate skin tones and wonderful, even color. I also use good glass, which is half the battle.
Old 27th of May 2006 (Sat)   #8
tim
Light Bringer
tim's Avatar
I 2nd this, though if you're careful you might get away without the bracket.
tim is offline   Reply With Quote
Old 27th of May 2006 (Sat)   #9
Eoseni
Eoseni's Avatar
Tim, I see you own the Pro-T bracket. What can you say about it? Would you buy it again? Or would you get another kind? which?
And also, you have the various diffusers: Omnibounce, LSII, 80-20 etc. Which one would you choose if you only had to choose one to do weddings? I want to get one that would "do-it-all." at least for now until I earn more....
I understand the LSII eliminates the need for a bracket. Is that true in your experience? Also, its shadows are the slightest among the other diffusers, right? If so, I'm thinking of getting the LSII to save money on a bracket.
Your thoughts and advise welcome, and thanks!
Old 27th of May 2006 (Sat)   #10
liza
I forgot to add earlier, Tim Wee, that the 10D's shutter isn't loud like that of the 20D.
Old 28th of May 2006 (Sun)   #11
jamiewexler
jamiewexler's Avatar
I'd almost be inclined to recommend the Tamron 17-50 f2.8 (if your budget can't stretch for the Canon 17-55). Despite my somewhat negative experiences with Tamron, it seems to be at least as good at the 28-75, and gives you the wide end you're missing with a fast aperture you're missing. 17-50 on a crop body is (IMHO) about as ideal a FL as you can get for weddings. 28mm (44mm on 20D) is too tight for smaller rooms and crowded dance floors.
As for the backup digital body (and light meter), I'd bump those to lower on the list. I shot with a film backup body for my first 5 weddings. I never needed to use it, but it was there just in case - that's all a BU needs to be, just in case. A faster lens and better flash are top priorities. I'd also recommend a faster prime for the really low light scenarios (50 f1.8/f1.4, 85 f1.8 ).
jamiewexler is offline   Reply With Quote
Old 28th of May 2006 (Sun)   #12
tim
Light Bringer
tim's Avatar
I've had a 20D fail in the middle of a ceremony a couple of times, so I consider it essential to have a backup with lens, CF card, and battery out and set up to the correct settings for the situation. I don't use a backup body exactly, I have two bodies on me at all times, with different lenses so I can get different shots quickly and easily.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Minimum equipment requirements for a good wedding shoot? Keydogg Weddings and Other Family Events 17 24th of July 2007 (Tue) 07:18
Topping up my Wedding Kit - Best Prices for Equipment MrTED Weddings and Other Family Events 6 7th of June 2007 (Thu) 05:38
Need Opinions of Equipment for First Wedding mebailey Weddings and Other Family Events 13 20th of April 2006 (Thu) 20:46
Wedding Equipment Setup mizuno Weddings and Other Family Events 30 6th of March 2006 (Mon) 15:35
Wedding equipment. Dubsta Weddings and Other Family Events Talk 2 14th of March 2005 (Mon) 20:05
