#1 |
i try to set a speed 1/400 sec with a built in flash is on..
but it`s automatically back into 1/250. but if a built in flash is off, i can set speed up to 1/250. does speed up to 1/250 need an external flash ??
G3 die hard |
| sponsored links |
#2 |
To go over 1/250 you need a high speed synch (external) flash like the EX420! At this time you expose for the background and you use the fill flash, usefull for pics in the sun to avoid heavy contrast.
| Thread Tools | |
| Display Modes | |
| $250 for a 2 flash setup... possible? | e r y k | Small Flash and Studio Lighting | 5 | 21st of July 2007 (Sat) 14:29 |
| Av mode with manual flash 1/4000 sec? | peatoire | Canon EOS Digital Cameras | 1 | 28th of August 2006 (Mon) 07:20 |
| Advice on deciding between 250/250 or 500/500 flash kit | Ineedhelp | Small Flash and Studio Lighting | 10 | 1st of December 2005 (Thu) 17:18 |
| Maxtor 250 GB External hard drive | Phil Hall | Accessories & Storage | 7 | 2nd of March 2005 (Wed) 22:32 |
| S200 External Flash Sunpak Digital Flash Adaptor | Soyboy | Small Compact Digitals by Canon | 0 | 27th of September 2004 (Mon) 18:36 |
