Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 2nd of June 2006 (Fri)   #1
hania
Default Agricultural Show
Took 17-55 IS USM + eos300d for its first outing outside.
Following advice from these forums, used 'm' setting.
Hope you like them.
#1 is the JCB Danging Diggers.
#2,#3,#4 local hunts giving a demo.
hania is offline   Reply With Quote
Old 2nd of June 2006 (Fri)   #2
hania
Default Re: Agricultural Show
and the other two
Old 2nd of June 2006 (Fri)   #3
Curtis N
Master Flasher
Curtis N's Avatar
Nice job with the exposure and capturing the action.
Most of them could benefit from some straightening. Try to get the flag poles in the background vertical.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 2nd of June 2006 (Fri)   #4
hania
Angry Re: Agricultural Show
Shall do & re-post later.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sha Na Na Rockin' Christmas Show, Pt. 2, (The Show) @ Penn's Peak johnstoy Performing Arts 25 26th of December 2006 (Tue) 12:20
Need Fashion Show Advice - Let's See Your Fashion Show Images ironbelle General Photography Talk 3 23rd of November 2006 (Thu) 01:23
Boys, If I show you mine - will you me show yours? dzstudios Transportation 1 7th of April 2006 (Fri) 07:15
