Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 3rd of June 2006 (Sat)   #1
beano
beano's Avatar
Default Hand held 300mm
I've borrowed a 75-300mm from a friend for the weekend, and was just wondering what would be a realistic shutter speed to hand hold this lens at 300mm, and not get camera shake?
Scott
1D mk2, 50mm 1.8, 17-40mm f4L, 400mm 5.6L, 1.4x Extender, 430EXii
flickr
beano is offline   Reply With Quote
Old 3rd of June 2006 (Sat)   #2
Woolburr
Mr. PMS Himself
Woolburr's Avatar
Default Re: Hand held 300mm
Conventional wisdom is 1/focal length or in the case of a 300 mm lens...1/300th of a second. Beyond that, most would also recommend that since you are using a 350D with a 1.6 crop factor sensor that you should also factor in for the sensor. Given that circumstance a minimum shutter speed of 1/500th (300mm focal length x 1.6 crop factor =480mm effective focal length...then 1/focal length) is a better choice to insure sharp images.
Crayons, Coloring Book, Refrigerator Art and What I Really Think About
Woolburr is offline   Reply With Quote
Old 3rd of June 2006 (Sat)   #3
tommykjensen
The Admin Dane
"Nobody is safe!"
tommykjensen's Avatar
Actually the speed would be minimum 1/480
I'll just repeat what Jon explained just one day ago.
Originally Posted by jon
You're right, the crop factor bit has been gone over repeatedly. I'll try to keep this brief and clear.
With a 200 mm (say) lens and the same shutter speed you'll get the same amount of shake at the sensor whether you're using APS-C or FF. That far, no problem, right?
Now here's where the "crop factor" comes in. Your desired output is an 8x10 print. So you need to blow up the FF shot 8x. You need to blow up the APS-C shot (8x1.6)x or 12.8x to get that same 8x10 print. It doesn't matter whether they're the exact same framing or not. To get an 8x10 from an APS-C, you need to enlarge it 1.6x more than you need to enlarge a FF. Right?
Now, when you blow up the original image you also enlarge the camera shake that was recorded, right? And since you've enlarged the shot from the APS-C 1.6x more than the FF, you've also enlarged the blur from the APS-C (which was the same as the blur in the FF original neg/capture) 1.6x more. So, since you enlarge the blur more, you need to have less blur on the sensor to get the same amount in the finished print. So you need a faster shutter speed.
Hehe Dan beat me to it but I think Jon's way of explaining it make it more clear why the crop factor need to be considered.
Best Regards Tommy
My Photos -=- about.me -=- My Facebook, if you add me please send me a pm also
GAPS Africa I 2007 photos -=- GAPS Africa II 2008 photos -=- GAPS Africa IV 2011 photos -=- GAPS = Great African Photo Safari
My marketplace feedback click here.
IMPORTANT: Image posting rules updated - please read.
"PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED."
tommykjensen is offline   Reply With Quote
Old 3rd of June 2006 (Sat)   #4
beano
beano's Avatar
Thanks for the quick replies!
I guess it's definitely a sunny day lens (or high ISO of course) without the tripod lol...
Scott
flickr
Old 3rd of June 2006 (Sat)   #5
phylet
phylet's Avatar
ive got a sigma 70-300 (APO) and i can get down to about 1/100 OK.
phylet is offline   Reply With Quote
Old 3rd of June 2006 (Sat)   #6
tommykjensen
The Admin Dane
"Nobody is safe!"
Not everybody have that steady hands so some can go lower some will need higher.
For example I got a shot of at 1/25 with my 300 mm f/4 IS prime. (Yes IS helped a lot there).
Best Regards Tommy
Old 3rd of June 2006 (Sat)   #7
::John::
My wife, the first time she used the 75-300 on the 350D was happily (and accurately) shooting around 1/100 and 1/125, too, so I know what you mean, phylet.
::John:: is offline   Reply With Quote
Old 3rd of June 2006 (Sat)   #8
Jon Foster
is it safe?
Jon Foster's Avatar
Does this 75-300 have IS? If so, you can drop a couple more stops with ease... Here's a high ISO night shot taken hand held.
Canon 300D, 75-300mm IS USM, Shutter speed: 1/13, F-stop: 8.0, ISO speed: 3200, Focal length: 80mm
Jon.
I shoot with a Little Canon
Check out my photos @ PBase.com & ModelMayhem.com
Jon Foster is offline   Reply With Quote
Old 3rd of June 2006 (Sat)   #9
beano
beano's Avatar
No it's the cheap one.
Scott
flickr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1000mm Hand-Held Linuxboy00 Birds 17 2nd of February 2007 (Fri) 23:18
Comet hand held! WepWaWep Wildlife 2 12th of January 2007 (Fri) 19:18
Hand Held-- C+C Please midnitejam Critique Corner 7 11th of September 2006 (Mon) 18:34
Hand held bellows? Shakespeare Accessories & Storage 2 6th of May 2005 (Fri) 12:25
G3 Macro Some Hand held. phili1 Macro 0 18th of November 2003 (Tue) 18:36
