Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 20th of April 2001 (Fri)   #1
C.N.
Default Photoshop question
What is the diffrence between Cmyk - RGB - and lab- colours ?
Which of the above should i choose to get the best printing results ?
Regards,
C.N.
C.N. is offline   Reply With Quote
Old 20th of April 2001 (Fri)   #2
Rick
Default Re: Photoshop question
C.N.
Thats an entire can of worms your asking about. It depends on so much that that there just isnt a single answer.
You can use RGB for home based stuff and messing around and professional inkjet printing.
CMYK is generally for going to prepress and for final printing with plates and a four color press, such as in advertising, commercial phtography and the like.
LAb is used in device independant work flows, it works great for going from one device to another and maintaining the look of a image. It is also an internal format used by Photoshop when changing an images format.
The things you need to do before you can ask your question are as follows.
What printer are you using or are you going to a pro job?
Does it have to be archival? What about color corectness, is it important?
What size image are we talking about for the final output?
Should the print be archival and on what kind of media do you want it printed?
Sorry to answer like this but you asked a big one
Rick
Rick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Photoshop Question Stime187 RAW, Post Processing and Printing 12 26th of September 2006 (Tue) 16:46
photoshop Question switchblade5984 RAW, Post Processing and Printing 4 10th of July 2006 (Mon) 12:34
first photoshop question bballboy30 RAW, Post Processing and Printing 1 8th of January 2005 (Sat) 18:59
question on how to do something in photoshop 7 gail RAW, Post Processing and Printing 6 2nd of June 2004 (Wed) 22:14
Photoshop CS question ZipMeister Canon EOS Digital Cameras 5 27th of November 2003 (Thu) 05:56
