Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 4th of June 2006 (Sun)   #1
adampacey
Unhappy Help with my new 1Ds MkII
Hi,
I have just got my 1Ds MkII and it's awesome ... but ... when I use my 17-40mm lens at anything less than about 35mm zoom the corners of the picture are cropped out (black) basically giving me a round picture. I know this must have something to do with the full frame sensor but am not sure how to fix it ... can't I use anything wider than 35mm with this camera??
Thanks in advance
Adam
adampacey is offline   Reply With Quote
Old 4th of June 2006 (Sun)   #2
Woolburr
Mr. PMS Himself
Woolburr's Avatar
Default Re: Help with my new 1Ds MkII
Which lens hood are you using? On a FF camera, you need to use the factory original (EW-83E) version to limit vignetting. Lots of people switch to the EW-83D for use on a crop camera like the 20D which will cause the problem on full frame.
Crayons, Coloring Book, Refrigerator Art and What I Really Think About
Woolburr is offline   Reply With Quote
Old 4th of June 2006 (Sun)   #3
weemannie
Welcome to the forums
Are you using any filters?
Regards, Trevor
5D MkIII, 60D, Zuiko 24mm, Zeiss ZE 21mm and 50mm 1.4, 70-300L, 10-22
http://www.scotlandimagery.com
weemannie is offline   Reply With Quote
Old 4th of June 2006 (Sun)   #4
adampacey
Hi,
I wasn't using any hood! The lens is the Canon Zoom EF 17-40mm L USM with a Hoya Cir Pol and UV filter fitted. When i tried to use it at 17mm the corners were blacked out.
Thanks for helping,
Adam
Old 4th of June 2006 (Sun)   #5
weemannie
Have you tried without the filters?
At wideangles there will be some vignetting, especially with 2 filters fitted.
Regards, Trevor
Old 4th of June 2006 (Sun)   #6
adampacey
will try now ... give me a minute!
Old 4th of June 2006 (Sun)   #7
Woolburr
Mr. PMS Himself
Woolburr's Avatar
ahhhhhhhhh.....the stacked filters are the culprit. Remove the filters and you should be golden. If you need a CPL on a FF camera, you probably need to look at the thin mount versions and never stack filters.
Old 4th of June 2006 (Sun)   #8
adampacey
problem solved - thankyou!! Looks like I'll have to switch to Cokin filters. One other quick question ... the 'on' button on the battery grip seems a little loose ... i get a click switchin it on but have to turn it a bit more to get it to work ... does that sound odd ... with such build quality i expected a firm click on and off?
Old 4th of June 2006 (Sun)   #9
weemannie
You'll need one of the really big filter systems Cokin XPro or ZPro. Although with that camera (envy, envy) I think Hitech or Lee filters would be better. Also look for wide angle adaptors rather thatn
Regards, Trevor
Old 4th of June 2006 (Sun)   #10
weemannie
You'll need one of the really big filter systems Cokin XPro or ZPro. Although with that camera (envy, envy) I think Hitech or Lee filters would be better. Also look for wide angle adaptors rather than standard.
As far as the switch is concerned, it doesn't sound right to me. My 1D has no problem like that.
If you want to send it to me, I'll try it out for you
Regards, Trevor
Old 4th of June 2006 (Sun)   #11
Woolburr
Mr. PMS Himself
Woolburr's Avatar
I don't know the answer to your switch problem. Mine seems pretty positive.
Old 4th of June 2006 (Sun)   #12
adampacey
Am using cokin P series on my 20D so will try that but if not will invest in a bigger system ... anything for my 1Ds MkII! They are expensive but it is just awesome although I need a new 500 Gig hard drive to keep the files on ... they're huge!
Thanks again ... any thoughts on that battery grip on/off switch ... just doesn't feel right?
Old 4th of June 2006 (Sun)   #13
adampacey
Hmmm ok the camera is in the post errr not!
My take it into a canon centre just to put my mind at rest.
Thanks again
Old 4th of June 2006 (Sun)   #14
prep
Get a CPL filter that fits the largest fron lens, an 82mm I think, and step rings to fit it to your smaller lenses. It will cost you an arm and both legs, but you only need to do it once!
~pr
prep is offline   Reply With Quote
Old 4th of June 2006 (Sun)   #15
adampacey
hi ... thanks ... whats CPL!?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sell 1Ds MkII and get 1D MkII n? OviV Canon EOS Digital Cameras 10 4th of January 2007 (Thu) 16:50
Is this the new 1Ds MKII N? Permagrin Camera Rumors and Predictions 12 17th of August 2006 (Thu) 13:18
1D MKII/MKII/1Ds vs D70 Dans_D60 Canon EOS Digital Cameras 2 12th of July 2005 (Tue) 22:42
1DS MKII or 1D MKII HKFEVER Canon EOS Digital Cameras 22 17th of December 2004 (Fri) 09:47
