#1 |
I convert the RAW image in RSE and import to PSE4 as TIFF (16 bit), but to save as JPEG in PSE4 (once ready to print), it has to be 8 bit.
Should I convert to 8 bit TIFF instead of 16 bit. And if so will I notice any difference in printed picture??
Jim 5D Mark III Grip, 40D Grip, 20D, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX It's the Glass that Counts! Visit http://www.genphotosaz.com |
| sponsored links |
#2 |
Why not just save the 16 bit TIFF? You won't likely see much difference in the print, but if you save in TIFF, you can save any layers you have in the image in case you want to make adjustments later.
#3 |
Almost all printers are 24 bit (8 bit/channel) devices. Since my output varies based on target device and/or print size, I keep a generic flattened 16-bit/channel .psd and the raw file. If you are going to edit after raw conversion, definately go with 16 bit color, and you can convert it to 8 bit later. This will result in much better color transistions and reduce banding. Depending on your print service, or printer, an 8 bit jpeg (highest quality) or 8 bit tiff should be fine.
| sponsored links |
#4 | |
#5 |
16 bit is not supported by jpeg format.
#6 | |
I've been shooting and editing in 16-bit, but the 16-bit images are really eating up my hard drive space. After I've made most of my corrections, is it okay to archive the images in 8-bit w/ layers intact? I may make minor adjustments later on... But 8-bit is all the printer accepts, and I've heard you couldn't really tell much difference between an 8-bit and 16-bit print anyway Of course, I keep the original RAW file. But I've been considering going through all of my files and converting to 8-bit to save space??Jim-mpix only accepts 8-bit images, and their prints are beautiful by the way.
Canon 20D 50mm 1.8 85mm 1.8 580EX(still trying to figure it out) Lightsphere II PS CS2 Mac OSX Apple Studio Display(LCD) www.vip.smugmug.com Critique and edits welcome |
#7 |
By generic, I mean that it is left as a flattened, full resolution, but with no crop/resize or output sharpening applied. This way, I can go back to it and make prints, thumbnails, web size, email, etc. in any size I want. If I want to make a changeg to my workflow up to that point, I can rework the original raw, but that isn't usually necessary. Even if I am not 100% satisfied with my results, I rarely go backwards with my work, preferring to shoot new subjects. The exception to that preference happened recently when I made some large prints of older work to display in a show. I wanted to be sure I displayed my best possible work, and, processing wise, some the 2-3 year old stuff was sub par compared newer stuff.
| Thread Tools | |
| Display Modes | |
| format for printing and 16 bit, 32 bit, etc. | azpix | RAW, Post Processing and Printing | 1 | 16th of November 2006 (Thu) 02:40 |
| Which version of Noise NInja - 8 bit or 16 bit? | Mike Bell | RAW, Post Processing and Printing | 5 | 18th of February 2006 (Sat) 13:41 |
| Converting from 16 bit Tiff to 8 bit Jpeg? | dennykyser | RAW, Post Processing and Printing | 3 | 8th of March 2004 (Mon) 11:03 |
| More colors in 8 bit JPG than in 8 or 16 bit TIF with Digita | The Photo Tuell | RAW, Post Processing and Printing | 8 | 27th of September 2003 (Sat) 15:21 |
| 16 bit linear tiffs to 8 bit question | gary shepard | RAW, Post Processing and Printing | 2 | 23rd of November 2001 (Fri) 13:07 |
