Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Macro
Reply
Thread Tools Display Modes
Old 12th of June 2006 (Mon)   #1
peterdoomen
peterdoomen's Avatar
Location: Lier, Flanders (northern, flemish speaking part of Belgium)
Default Which camera/lens combo for macro?
A collegue of mine wants to start with macro photography, especially flowers. What would be a good & not too expensive camera/lens combo to start with?
I was thinking a 350D or used 20D body with a Canon EF 50mm f/2.5 Compact Macro (combo around €1000).
Other ideas? Thanks!
P.
Canon EOS 20D | Canon 70-200 f2.8L IS + Hoya UV Filter | Canon Extender 1.4x | Canon 50 f/1.8 | Canon 85 f/1.2L mk II | Tamron 17-35 f/2.8-f/4| Tamron 28-75 f/2.8 | Tokina 100 f/2.8 macro | Kenko extension tubes | Canon Speedlite 420 EX & Sto-fen Omnibounce| 80GB Flashtrax | Manfrotto Tripod 190 pro B & Joystick 322RC2 | Lowepro Micro Trekker 200
PDFs: Make money with ShutterStock - Make your own Tabletop Studio - Glass Buying Guide
My ShutterStock Gallery
peterdoomen is offline   Reply With Quote
Old 12th of June 2006 (Mon)   #2
LordV
LordV's Avatar
Default Re: Which camera/lens combo for macro?
Fine on camera and lens as long as they only want to stick to flowers and no amazing closeups (unless you get ext tubes as well) otherwise I'd be tempted to recommend a 1:1 capable lens- 60mm EF-s, 90mm tamron, 100mm canon or 105mm sigma are all good lenses. Might also depend on what other uses they might put the lens to.
Brian V.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is offline   Reply With Quote
Old 12th of June 2006 (Mon)   #3
dpastern
User is banned from forums
Hey Peter,
I'd most probably go with the 2nd hand 20D (more future proofing and room to grow) and a Sigma 105mm. Add a set of Kenko tubes and a Sigma 1.4x TC down the track if he/she wants to get closer. The 350D will be lighter than the 20D, so if they don't really want to future proof things they could go the 350D and shave a few grams, which will make it easier most probably to hold the camera still and get sharp shots.
Dave
dpastern is offline   Reply With Quote
Old 13th of June 2006 (Tue)   #4
peterdoomen
Brian, Dave: thanks for the reply. I'll tell her to consider a used 20D with a 1:1 macro. Tamron or Sigma, depending on the focal distance she needs.
P.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
The only guaranteed way of keeping your lens / camera combo in pristine condition. neil_r Canon EF and EF-S Lenses 44 20th of April 2007 (Fri) 20:49
Macro and/or combo for outdoors? Mollym/CA Canon EF and EF-S Lenses 10 18th of October 2006 (Wed) 12:17
Best field sports two camera combo? Tandem Sports Talk 9 27th of July 2006 (Thu) 09:24
Your thoughts on this lens, t-con, camera combo lomond Canon EF and EF-S Lenses 7 12th of May 2005 (Thu) 13:36
Macro Combo drisley Canon EOS Digital Cameras 1 27th of May 2004 (Thu) 03:18
