Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Presentation
Reply
Thread Tools Display Modes
Old 16th of June 2006 (Fri)   #1
Karl C
Location: Now: N 39°36' 8.2" W 104°53' 58"; prev N 43°4' 33" W 88°13' 23"; home N 34°7' 0" W 118°16' 18"
Default Website/Gallery design help and/or info
I've been slowly working on designing my own site and had a question for those experienced in HTML and XHTML.
Which version is better? Or should I stick with XHTML for it's syntax error-check capabilities?
I ask because I ended up attempting to design in GoLive2 using Transitional XHTML but running "Check Syntax" comes up with a lot of errors that I can't seem to fix (or I "fix" based on Adobe's check but then I get other problems).
I'm a novice at web design and please accept my apologies if this has already been asked.
Also, I've tried to install Gallery 2 on Godaddy.com webservers but can't seem to get the Pre-Installer program to work. I get a "D drive not writeable" error.
Maybe I should just stick with pbase.com...
Thanks!
Gear: Kodak Brownie and homemade pin-hole cameras. Burlap sack for a bag.
Karl C is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wedding Website Design bcap Weddings and Other Family Events 22 30th of June 2007 (Sat) 22:41
Website design and Gallery Tareq Presentation 10 26th of December 2006 (Tue) 22:39
new website design dpurslow The Business of Photography 1 2nd of August 2006 (Wed) 07:31
Website design - what software? DocFrankenstein The Business of Photography 77 20th of May 2006 (Sat) 17:04
Possible new website design rlhphotos The POTN Lounge 6 17th of May 2006 (Wed) 14:32
