Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 6th of October 2003 (Mon)   #1
altus
Default LCD shut off
Please help me I just bought a canon s50 I took some photo and everything seem good but now I can take photos with the viewfinder but the LCD screen is black
except for the setting I can use it but not to take photos
what should I do
Thank you
Pierre
altus is offline   Reply With Quote
Old 6th of October 2003 (Mon)   #2
rrowley
Default Re: LCD shut off
I had this happen to me shortly after I got my s40. There may be a button labeled display on the back of the camera. It is used to turn off the lcd when you don't need it. Like to conserve battery power. I thought I had broken my new camera then discovered that I needed to press the display button. You probably already checked that, but it is worth a shot.
rrowley is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
open and shut kingsown Macro 12 14th of July 2007 (Sat) 17:42
Keep your mouth shut !!! ATBphotography Macro 5 20th of June 2006 (Tue) 14:58
Cut n Shut storeman Still Life, B/W & Experimental 10 29th of March 2006 (Wed) 11:37
Please shut the gate SimonBl Nature & Landscapes 4 25th of October 2005 (Tue) 07:58
A40 won't shut down... amatthews Small Compact Digitals by Canon 1 20th of December 2002 (Fri) 06:26
