Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 23rd of June 2006 (Fri)   #1
Rumjungle
Rumjungle's Avatar
Default Suggestions for a lowepro slip lock for 580ex?
I'm looking for a slip lock case that will fit the 580ex with an omnibounce. Any ideas?
Gear
Rumjungle is offline   Reply With Quote
Old 24th of June 2006 (Sat)   #2
claudermilk
Default Re: Suggestions for a lowepro slip lock for 580ex?
Take a measurement of the flash & hit the Lowepro site? They list the pouch dimensions.
20D/BG-E2/Katz Eye | Tokina 12-24/4 | 24-70/2.8L | 50/1.8 Mk I | 70-200/2.8L | PD70X
claudermilk is offline   Reply With Quote
Old 24th of June 2006 (Sat)   #3
Rumjungle
Rumjungle's Avatar
I was just wondering if anyone was already doing something like this. I'll check out the website, thanks.
Gear
Old 25th of June 2006 (Sun)   #4
DavidW
I sometimes put a 580EX, Omnibounce and a D-Res 6 (Lowepro battery and card wallet) in a Sliplock Pouch 50AW. The Omnibounce goes under the D-Res 6. It fits, but it's right on the height limit.
I picked up this idea from a web site where someone mentioned that they were using a Sliplock Pouch 50AW to carry two 580EX flashes.
David
DavidW is offline   Reply With Quote
Old 25th of June 2006 (Sun)   #5
Jack W.
I have this one from Think Tank:
http://www.thinktankphoto.com/ttp_pr...LghtnngFst.php
My 580EX+Omnibounce fit perfectly.
Jack
20D, 30D, 500f/4L IS, 300f/4L IS, 300f/2.8L IS, Canon 1.4TC, Canon 2xTC, 70-300IS, 17-85IS, EFS 10-22, Sigma 150 Macro, 3021PRO, RRS BH-40LR, Gitzo 1325, full Wimberley Head v2, Wimberley Sidekick, and a bunch of other stuff.
Jack W. is offline   Reply With Quote
Old 26th of June 2006 (Mon)   #6
Rumjungle
Rumjungle's Avatar
Thanks for the suggestions! While I like the Think Tank setup, I've already got the Lowepro belt. However, I also have a D-Res 6 and wouldn't mind some AW protection for it. I'll check out the Pouch 50 AW.
Gear
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Best Way To Strap Tripod to Slingshot 200 Side Slip Lock? Brian Puccio Accessories & Storage 2 1st of May 2007 (Tue) 20:15
Separate FE Lock & AE Lock which bodies peatoire Canon EOS Digital Cameras 2 28th of September 2006 (Thu) 07:35
Inexperienced with 580EX Flash! Any suggestions? cargo123 Small Flash and Studio Lighting 21 22nd of March 2005 (Tue) 08:21
Non-slip surface r0nbo Small Compact Digitals by Canon 3 27th of November 2004 (Sat) 12:33
The French slip vvizard Canon EOS Digital Cameras 1 28th of January 2004 (Wed) 12:37
