Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 24th of June 2006 (Sat)   #1
PORSCHE118
Default Shooting Fireworks....
...please advise me on best settings for taking shots at fireworks display. Canon Rebel XT. Would a EFS 18-55mm be ok? Thanks alot.
PORSCHE118 is offline   Reply With Quote
Old 24th of June 2006 (Sat)   #2
Eastcoast
Eastcoast's Avatar
Default Re: Shooting Fireworks....
You can use this lens if it is all you have. You can use any lens at all although most seem to use a fairly wide lens. There are quite a few posts about what settings to use, try searching for "fireworks" and "settings" and see what pops up.
This is just one from that search
http://photography-on-the.net/forum/...works+settings
John
Eastcoast is offline   Reply With Quote
Old 24th of June 2006 (Sat)   #3
Tee Why
"Monkey's uncle"
Tee Why's Avatar
First, scout a good location where you can get set up prior to the event. Make sure that the lens is clean as shooting at bright lights at night will tend to show flares and what not, especially if you use a UV filter. I'd probably take it off, if you have one. Set up your tripod and if you have one, use a remote shutter release.
Wear a light colored shirt so you don't get run over by cars or stuff and bring a small light with you.
Set your ISO to 100 for least noise and turn the noise reduction off as it takes longer to write the image if you do. If you shoot RAW, you can reduce any noise on the computer.
As for shooting parameters, I'd recommend manual mode, perhaps f16-19 for max DOF and shutter speed around 5-10 sec to start things off. If you find that it's underexposed, you can ajust the shutter time so that it's longer and/or open up the aperature a bit more. Reverse if over exposed. If you aren't comfortable with manual, you can try Tv mode and select the amount of time you want. I think depending on how many explosions you want to catch in one image, you can experiment with shutter speeds like from 1 sec or so to 15 or so sec's. It all depends on your taste.
Here's one I took at the Rose Bowl last year, ISO 100, Tv 5sec f22
Good luck and have fun.
Gallery: http://tomyi.smugmug.com/
Tee Why is offline   Reply With Quote
Old 24th of June 2006 (Sat)   #4
MagentaJoe
psycho clown
MagentaJoe's Avatar
Location: Having breakfast at the circus, with the lions and the clowns.
Don't forget that you have to manually focus before hand.
Arguing with a psycho clown can be harmful to your funny bone.
5D-Grip, 40D, 35f2, 50f1.4, 85f1.8,100f2.8macro, 135f2.8sf, 17-40f4L, 24-70f2.8L, 100-400f4.5-5.6isL, 580ex, 420ex, 430ex, 430ez
MagentaJoe is offline   Reply With Quote
Old 25th of June 2006 (Sun)   #5
PIXI_666
PIXI_666's Avatar
I set up my camera on a tripod, to bulb setting, then just used my cable release to do short exposures and long exposures...shorter ones seem to work better....
Its dead easy once you get the hang of it, practice with sparklers and candles...
(Oh and focus to infinity)
"Capturing, Creating & Preserving your memories"
Adelle Cousins Photography
www.adellecousins.com.au
info@adellecousins.com.au
PIXI_666 is offline   Reply With Quote
Old 25th of June 2006 (Sun)   #6
Woolburr
Mr. PMS Himself
Woolburr's Avatar
There really are no hard and fast rules for fireworks. You can shoot with a tripod if you want results that look like this:
But it is fun to handhold shots and get results like this:
Try ISO 100, f/5.6 and 1 second for starters...manual focus. The first time you shoot them, you may want to try a variety of settings...just to see what works best for you or what gives you the look that you are hoping to achieve. Fireworks are great fun and a great opportunity to experiment.
There is lots more info listed in this thread...Fireworks
Crayons, Coloring Book, Refrigerator Art and What I Really Think About
Woolburr is offline   Reply With Quote
Old 27th of June 2006 (Tue)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
Pyrotechnic Photography Techniques
http://photography-on-the.net/forum/...d.php?t=128028
Quick advice needed on Australia Day fireworks settings?
http://photography-on-the.net/forum/....php?p=1118006
firework photography help
http://photography-on-the.net/forum/....php?p=1537103
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 27th of June 2006 (Tue)   #8
staciecd
staciecd's Avatar
Do you have to use manual focus?
Digital Rebel XT 350 | Kit Lens, 50mm f/1.8 II, 17-40mm L, 70-200mm f4 L, 70-200mm f2.8 IS, 15mm Fisheye
Speedlight 580EX II, 2 PocketWizard Plus II
Stacie's Portfolio Updated Feb 2008 | Stacie on Flickr
staciecd is offline   Reply With Quote
Old 27th of June 2006 (Tue)   #9
Davinor
Davinor's Avatar
Fireworks play havoc with the AF. Get there early, find out where the fireworks are located, get the camera on the tripod and focus on something near to where they are - then switch the lens to manual. After that sort out the exposure making sure that you have a reasonable DOF and leave the focus alone.
A tidy desk is the sign of a sick individual
600D with Sigma 17-70 f2.8-4 DC OS HSM,
Tamron 70-300 f4.5-5.6 Di VC USD
Sigma EF500 DG Super and some other bit and pieces
Davinor is offline   Reply With Quote
Old 27th of June 2006 (Tue)   #10
daclozer
daclozer's Avatar
wow, davinor.. That last pic is awesome. Nice work.
2 30D/BG-E2
70-200L f2.8 Canon
28-75mm f2.8 Tamron
www.freezeframefoto.biz
http://www.etsy.com/shop/freezeframefoto
daclozer is offline   Reply With Quote
Old 27th of June 2006 (Tue)   #11
PhotosGuy
Moderator
PhotosGuy's Avatar
then switch the lens to manual. .. and tape the focus ring! (Trust me on this!)
www.FrankCizek.com
Old 28th of June 2006 (Wed)   #12
Davinor
Davinor's Avatar
Fireworks are FUN, once you are set up just keep hitting the shutter button - not literally, use a remote release. After a twenty minute display I had around 150-180 images, by the time you have whittled out the garbage (total white out through to black with a lone streak of light) there are usually around 30-50 decent ones that you are happy with.
David
PS Daclozer - Thank you
Old 28th of June 2006 (Wed)   #13
PhotosGuy
Moderator
PhotosGuy's Avatar
If you got PSE with your 350 & if it has Blend Modes, you can group a set of single shots into one. In the Post Processing Tutorials List , look up PS Blend modes can make a shot out of "nothing"! Try them all to see what they will do.
The easiest way I've found to keep track of what each blend mode will do with a particular pic is to cycle through them with Shift+Alt+ (+ or -) to see the results. After a while you get a feel for what they will do.
www.FrankCizek.com
Old 28th of June 2006 (Wed)   #14
liza
User is banned from forums
Here's a good link:
http://www.porterscamerastore.com/newsletter0605.shtml
I used a Tamron 28-75 and a sturdy tripod for my fireworks shots, which worked out pretty well. I also shot them in RAW.
liza is offline   Reply With Quote
Old 28th of June 2006 (Wed)   #15
tmerrick
Here is what I am thinking/planning on using:
Lens: Either my 70-200 f4 L or my 28-105 f3.5-4.5. Manual Focus set to infinity (probably)
Tripod and Cable Release
Highest quality: RAW + JPEG or just RAW
Lowest ISO: 100-200
AV: f8-f11
Shutter: Bulb – controlled by remote cable release (2 – 20 sec.) open shutter when you hear it launched
Custom Functions: Long Exposure Noise Reduction = True
Mode: Manual or Program Auto
Tyler Merrick
www.tylermerrick.com
5DMK2, 135 f/2L, 24 1.4L, 50mm f/1.8,550EX, Bogen/Manfrotto 3001BN/488/RSS PCL-1,RRS Pano Elements, Tenba Messenger Bag
tmerrick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fireworks shooting megdilts General Photography Talk 2 28th of April 2008 (Mon) 16:52
Shooting Fireworks? jcrane Canon EF and EF-S Lenses 21 28th of June 2007 (Thu) 23:01
Shooting fireworks lummy Performing Arts 6 4th of July 2006 (Tue) 04:10
First Try shooting fireworks GMosher Urban Life & Travel 9 5th of July 2005 (Tue) 11:26
Shooting fireworks with IS Skids Canon EOS Digital Cameras 10 4th of November 2004 (Thu) 10:48
