#1 |
I currently own a 350D and am thinking about getting a 30D. The type of shooting I do is sports (specifically bicycle racing) with a Sigma 70-200 f/2.8
My question is twofold: 1.) I'm not completely happy with the AF on the 350D. Will I see a noticible difference in AF accuracy on the 30D? 2.) I want to do as little PP as possible. I love RAW and use it all the time, but for bike racing, I shoot several hundred pics in a session and don't have time to PP every one. I use batch mode, but you still have to go through every picture. The 350D sharpening parameter setting goes to a value of "3", I'm fairly sure the 30D in camera sharpening parameter goes to a max. value of "7" I'm not sure how the two values relate to each other, but with sharpening set to the max on both cameras, will the 30D result in sharper images? A buddy of mine shoots with the same Sigma lens, but uses a Nikon D70. He does no PP for his race photos, and his images are WAY sharper than mine. I also like the faster FPS, larger LCD, and spot metering on the 30D. Those alone are probably good enough reason alone to upgrade. But AF accuracy and in-camera jpeg sharpening are inportant to me as well.
*cameras: Canon 1D Mark III/1D Mark II/& 1D "Classic" *lenses: Canon 50mm f/1.8 | Canon 85mm f/1.8 | Canon 300L f/2.8 IS | Canon 70-200L f/2.8 IS | Canon 16-35L f/2.8 | Canon 1.4x TC II *accessories: Canon 580EX II/430EX | CP-E4 http://www.cyclingcaptured.com |
| sponsored links |
#2 |
Formerly known as Bluedog_XT
a simple yes to # 1.
. Canon EOS 50D| Canon EF-S 10-22mm f/3.5-4.5 | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS | Canon 70-200mm f/4L My PBase Gallery |
#3 |
User is banned from forums
#1 Yes, it's at least 3x faster.
#2 Post processing is a fact of life with DSLR's. I shoot sports, too, and process a several hundred images per week throughout the school year. The key is to establish a good workflow to create a quality product. |
| sponsored links |
#4 |
I agree with the auto focus. I sent mine in for calibration. It came back much better as long as I am using center focus point. The noise above ISO 200 is also unacceptable to me. Like to hear if noise is better on the 30d as well.
Canon 40D, 5D MK II Speedlites 430EX & 580EX II Canon 70-200 f/2.8L (Non IS), Canon Extender EF 1.4 X II, Canon 400 f/5.6 L, Canon 100 f/2.8 Macro, Canon 24-70 f/2.8L |
#5 |
I'm no expert, but i do own the 30D with 16-35L, 24-70L, and a 70-200L all f/2.8. I've noticed that my 70-200 seems to be the sharpest of the 3. Also, many people have told me that a different copy of any given lens may be sharper also. So maybe the sharpness issue is with the copy of your lens?? Don't know, but i've got the internal sharpening set to 4 and it seems that if i do ANY PP sharpening, the image looks over sharpened.
As far as noise goes, i don't see it to be a problem as high as 600. |
#6 |
I went from the 300D to the 30D and found the AF much better. My percentage of keepers has certainly increased. As other poster have said there may be just natural variation between copies of the lenses you and your friend have. Noise is better on the 30D than it was on my 300D.
Greg Blog | Photogallery | 1DmkIII, 40D + other stuff that sticks to the front of them. Sanity is a madness put to good use. |
#7 |
I have a 30D and don't do any post processing. I find the in-camera processing more than acceptable for my uses. I use the "portrait" picture mode most of the time set at +3 sharpness, -1 contrast, and +1 saturation. I try to avoid post processing just because of the time required.
#8 | |
#9 |
Canon cameras are softer because of strong anti-aliasing. I bet that D70 has crazy amount of Moire lines too.
#10 |
"Monkey's uncle"
#1 yes, esepcially with lenses f2.8 and faster.
#2 not sure. In DPP you can use the picture style on jpeg images and batch convert them, so it shouldn't be any different. |
#11 |
From what I read into it from the below links which are extensive reviews. The noise levels from the 20D/30D are minimally better than the 350D.
http://www.dcresource.com/forums/showthread.php?t=6179 http://www.dpreview.com/reviews/canoneos350d/page19.asp
Canon 40D,30D, 350D, 24-70 2.8L, 10-22, 17-40 4.0L, ef 50 f/1.8 II, ef 50 1.4, 70-200 2.8L, Sigma 24-70 F2.8 DG EX, 18-200 OS, Canon 2x Conv, Canon 580 EX flash, Omnibounce, Lightsphere II (clear), WhaleTail. X-Drive VP6230 120 GB photo store. Sports photos NRL rugby league Australia. http://www.byronimages.net |
| Thread Tools | |
| Display Modes | |
| 350d v 30d | markyb | Canon EOS Digital Cameras | 13 | 3rd of February 2007 (Sat) 17:36 |
| 350D to 30D | darktiger | Canon EOS Digital Cameras | 9 | 16th of October 2006 (Mon) 21:59 |
| 5d or 30d or 350d | Treat me like a tourist | Canon EOS Digital Cameras | 12 | 24th of August 2006 (Thu) 14:00 |
| 350D to 30D | keeper | Canon EOS Digital Cameras | 22 | 16th of August 2006 (Wed) 02:46 |
| 350D or 30D | Coops61 | Canon EOS Digital Cameras | 10 | 21st of March 2006 (Tue) 19:11 |
