Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 6th of July 2006 (Thu)   #1
keenasmustard
keenasmustard's Avatar
Question ACR Auto Settings Question
Hi,
I was wondering if there is a way to make ACR not default to having all of the auto settings checked in the first "adjust" tab?- ie exposure, shadows etc. I have been advised to uncheck these and make my own adjustments, but I want a way to save the time it takes to manually uncheck them. Hope that makes sense.
keenasmustard is offline   Reply With Quote
Old 6th of July 2006 (Thu)   #2
gpocock
Default Re: ACR Auto Settings Question
I think Control-U will do it
Best wishes
Geoffrey Pocock
gpocock is offline   Reply With Quote
Old 6th of July 2006 (Thu)   #3
keenasmustard
Thank you very much Geoffrey! That did the trick!
Old 6th of July 2006 (Thu)   #4
Nick C.
Nick C.'s Avatar
If you don't want auto adjusting on any raw image you can 'Save New Camera Raw Defaults' after you Ctrl+U too.
Nick
Nick C. is offline   Reply With Quote
Old 7th of July 2006 (Fri)   #5
jfrancho
jfrancho's Avatar
Set WB to Auto or As Shot
Exposure to 0
Shadows to 0
Brightness to 50
Contrast to 25
Saturation to 0
Then Save New Camera Raw Defaults from the flyout menu.
You may want to go to the other tabs and set some other common default settings. I chose a medium contrast curve and sharpening (preview only) set to 35 as my defaults as well.
EDIT: Fixed default Brightness to read "50" instead of "0".
jfrancho is offline   Reply With Quote
Old 7th of July 2006 (Fri)   #6
DavidW
I would have Brightness at 50 by default - but apart from that, I'd say jfrancho is on the mark.
David
DavidW is offline   Reply With Quote
Old 7th of July 2006 (Fri)   #7
Nightcrawler
Nightcrawler's Avatar
David
Agreed. That's what I have my defaults at.
Jason - Gear - Site
Nightcrawler is offline   Reply With Quote
Old 7th of July 2006 (Fri)   #8
jfrancho
jfrancho's Avatar
David
Yes, 50 is default. Sorry about that. I'll fix the list. Thanks
Old 7th of July 2006 (Fri)   #9
cyclone
cyclone's Avatar
and then make sure you hit done.
20D · elan7 · G2
ef24/2.8 · ef50/1.8 · ef85/1.8 · efs10-22
tamron 28-75/2.8 · 70-200/4.0 · 100-400
420ex · other stuff
cyclone is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ACR custom settings jdizzle General Photography Talk 1 31st of May 2007 (Thu) 08:09
Do you use all ACR settings or some in CS2? gwc1023 RAW, Post Processing and Printing 3 12th of February 2007 (Mon) 23:48
ACR settings, questions Neon01 RAW, Post Processing and Printing 13 5th of September 2006 (Tue) 22:38
ACR- how to change default for Auto settings? summerwind4 RAW, Post Processing and Printing 1 26th of February 2006 (Sun) 07:46
ACR Settings??? bryno74 RAW, Post Processing and Printing 6 4th of February 2006 (Sat) 22:28
