Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 27th of October 2003 (Mon)   #1
steal_your_face
Default taking shots during dark indoor concert
greetings group,
I'm off to see Phish in the near future and am looking to taking oodles of shots. My last batch of concert photos turned out beyong horrible.
i have the A70 powershot and the specs i've got for it ar e
iso 400 (top speed)
f-stop 2.8
shutter speed 15-1/2500 sec range
my question is: with my max iso being so low, will a fast shutter speed make up for it?
am i on the right track with this, or am i setting myself up for failure. any help is much appreciated
thank you
justin
steal_your_face is offline   Reply With Quote
Old 27th of October 2003 (Mon)   #2
CyberDyneSystems
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
CyberDyneSystems's Avatar
Default Re: taking shots during dark indoor concert
You will need a SLOW shutter speed,. (the longer the shutter is open the more light can get in)
You can do either of two things,.
ISO @ 400 set apeture priorty to f/2.8 (letting in the most light) and let shutter speeds fall where they may to get you proper exposure. With these settings you will most likely get some photos with motion blur depending on how bright the stage is lit. But some times a motion blur can be nice!
ISO@ 400 and set the shutter priority to 1/125 to stop motion blur. Most of the time 1/125 is all you need to stop the motion. In this case blur should rarely occur,. instead you will sacfrifice LIGHT,. some images may be too dark,. others may be pleasingly moody and if the lights get too bright than the aperture can close down as needed on its own to prevent overexposure.
The second is usually how i shoot in the theatre,. unless I ma in fact looking to get a nice motion blur,.
CyberDyneSystems is offline   Reply With Quote
Old 27th of October 2003 (Mon)   #3
CyberDyneSystems
p.s.
Steal_your_face,
......got any pics of Motorhead?
Old 27th of October 2003 (Mon)   #4
steal_your_face
nope, no morothead pics here..
thanks for the help...i've got the first row in the balcony so hopefully the blue will be negligible
but i DO want the 2.8f and not the 4.8 right
Old 2nd of November 2003 (Sun)   #5
steal_your_face
anybody else got any recommendations
Old 2nd of November 2003 (Sun)   #6
RichardtheSane
RichardtheSane's Avatar
I have some concert shots on my website that i suspect are similar to what you hope to achieve.
I was using 1/20th-1/60th of a second as F3.5-F4.5 ISO 800 for the majority of the shots and they came out ok.
I should think if you set to ISO400 and F2.8 you will get the best results possible.
If you are not close enough to the stage that it fills the frame then set centre weighted metering if your camera has it, as matrix will try to compensate for the darkness around the stage and blow out the stage itself.
Oh, and turn off the flash!
CDS, next time Moterhead do my local I'll pop in and shoot a few for you
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
RichardtheSane is offline   Reply With Quote
Old 3rd of November 2003 (Mon)   #7
Yance
You are testing the limits of your camera with concert photos. I'd do it strictly with high speed film, maybe you should borrow a film camera with a 200mm? At slow shutter speeds you are going to have to deal with camera shake and also subject movement. Usually those two things in combination wreck good photos unless you want an art shot. Sorry, man
Yance is offline   Reply With Quote
Old 4th of November 2003 (Tue)   #8
steal_your_face
thanks for all your input
yea, the place i'm going doesn't allow cameras, so i'd have to stealth it, which means i can't bring out the 'big toys'...
i'll be on the first row in the upper level, so i'll have the wall to set the camera on...
thanks again on the centre weighted metering..i'll see if i can set that up
..and i'll post a few of the good ones, if i'm lucky to capture it well
--justin
Old 4th of November 2003 (Tue)   #9
RichardtheSane
Stealth it eh - did that with my 10D a couple of months back
A very good reason to double check the flash is turned off!! It would be like a magnet for security!
Old 6th of November 2003 (Thu)   #10
AcesHigh
Motorhead Nice, I didnt knew there were metalheads in this forum. Anyone likes bands like Black Sabbath, Iron Maiden, Dio, Rainbow, Deep Purple, Uriah Heep, Rush, Running Wild, Accept, Saxon, Judas Priest, etc?
AcesHigh is offline   Reply With Quote
Old 10th of November 2003 (Mon)   #11
steal_your_face
thanks again...
am i missing any other pertinent information..
btw i've got a live rush show from 2000 on disc if anyone would like a copy let me know
Old 10th of November 2003 (Mon)   #12
RichardtheSane
Default Re: Re: taking shots during dark indoor concert
Trust me - there is at least one
Old 10th of November 2003 (Mon)   #13
dog010
I've shot some shows with my G3 at 1/40 @ f3.0 which is nearly what you'll get with the A70 I think at full wide angle. If you're too far away, try switching your metering system to spot mode as this will limit the meter to the AF frame so you'll be able to pick a mid level bright spot to guage from.
I don't know how AF will cope in this situation so if you're some distance away you might be better off sticking it on infinity MF and leaving it there.
Good Luck and Have Fun,
dog010 is offline   Reply With Quote
Old 11th of November 2003 (Tue)   #14
bladerunner2000
Well, here is another one.
bladerunner2000 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Shooting at a indoor concert? TeriD Performing Arts 13 6th of June 2007 (Wed) 10:33
taking indoor group shots freefallu The Business of Photography 5 24th of September 2006 (Sun) 11:50
How do you read the histogram when taking bright/dark shots? robert_a_woods Canon EOS Digital Cameras 27 15th of June 2006 (Thu) 10:19
A70 - Indoor Pics Too Dark Beretta Small Compact Digitals by Canon 8 15th of November 2005 (Tue) 21:22
Dark Indoor Photos with G1 Shawn Canon G-series Digital Cameras 5 6th of October 2002 (Sun) 08:37
