#1 |
Ok I live in South Florida and upon exiting an air conditioned environment to go outside in the heat/humidity my camera lens foggs up something terrible. (So do my glasses but they clear up on their own rather fast but the camera lens doesn't). I mean it is bad and you can actually see condensation forming on the lens.
Is there a simple solution for this/ Thanks.
A camera. Trinkets galore. |
| sponsored links |
#2 |
As per CorruptedPhotographer stated in another thread "Before going to the outside, put the lens in a ziplock bag and leave it outside till the body temperature of the gear changes to the outside temperature. When it does, take it out and use it, this way it will not fog up because there is no sudden change (to the gear) temperature wise."
Kevin Thinking of getting a new gear, not sure if it's the right choice ? www.RentCameraGear.com |
#3 |
maybe try leaving it in the trunk (where air-con is limited or not at all) instead of inside the vehicle where the air-con is blowing.
Rob - "a photographer is a painter, in a hurry!" Canon 7D ~ Canon EF 70-200mm f/2.8L IS MKII ~ Canon EF-S 17-55mm f/2.8 IS ~ Canon EF 50mm f/1.8 II ~ Canon 430EX ~ Canon 580EXII ~ Canon EF 2.0X III Telephoto Extender ~ Canon SX230 HS |
| sponsored links |
#4 |
good quote KevNJ
#5 |
Hi, try searching on the net for dew heaters or dew bands, I use them in my other hobby of astronomy to stop dew forming on the optics of my telescope (just the same as the fog you descibe), but have also used them on camera lenses when taking long exposures at night, either that or use a small 12 volt powered hair dryer (which I also use)
Alan
Canon 1D mark III, Canon 20D, Canon 300D IR modded, Canon G12, Canon EF 17-40 f/4L USM, Canon EF 24-105mm f/4L IS USM, Canon EF 70-200 f/4L USM, Canon EF 300mm f/4L IS USM, Canon 1.4x converter, Canon EF 100mm f2.8 USM macro, Canon EF 50mm f/1.8 II, Peleng 8mm, Canon 580EX, Sigma EM-140DG |
#6 |
Put the hair dryer on the lowest setting and blow it at the glass, to kinda warm it up
#7 |
I'm comfortable with my masculinity
Put a filter on the lens. Then take some white liquid hand soap. VERY little amount and buff it onto the filter. The haze will go away after you buff it a bit. If you have a cheap filter that fogs in between then take your own risk buffing soap onto the lens.
I had to do this to my lenses in the caribbean since they would fog so badly in the humdity. Without it I got very "english" looking shots when it was too humid. Motorcyclists and hockey players use this old trick to keep their visors from fogging.
jasonhollister.com Think your camera is noisy at high ISO? Click here People will always try to stop you doing the right thing if it is unconventional |
| Thread Tools | |
| Display Modes | |
| The best way to eliminate an unwanted backgroun? | Picture North Carolina | RAW, Post Processing and Printing | 16 | 15th of May 2007 (Tue) 16:23 |
| How to eliminate this? | ladybelle2k | Birds | 3 | 13th of May 2006 (Sat) 10:36 |
| Fog on the lens...what do you do? | Parmcat | Canon EOS Digital Cameras | 7 | 12th of February 2006 (Sun) 23:36 |
| cleaning salty air / mist / fog from lens | gordeaux | Canon EF and EF-S Lenses | 4 | 5th of July 2004 (Mon) 05:46 |
| Lens Fog Issue | togoble | General Photography Talk | 1 | 22nd of June 2003 (Sun) 05:31 |
