Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 7th of August 2006 (Mon)   #1
lippy113
lippy113's Avatar
Default Too Dark
hi i took this picture earlier as we were out i havent had much experience with my flash can anyone help me please ? tell me what i am doing wrong ?
all the pictures i seem to take inside in low light always seem dark
Canon 30D
Sigma 24-70 F2.8 EX DG Macro
Speedlite 580 EX
all pictures have been hand held
Shooting mode Auto
Av 4.0
tv 1/60
ISO 400
Focal length 24mm
W/B Auto
lippy113 is offline   Reply With Quote
Old 7th of August 2006 (Mon)   #2
AirBrontosaurus
AirBrontosaurus's Avatar
Default Re: Too Dark
What metering mode were you usuing? Also, was the flash diffused? Bounced? Direct?
That looks like a pretty large area. I'm no flash expert, but I think it would take a heck of a flash to light up all the areas, including the ones at the back corner.
If you shot it in RAW, this shot might benefit from HDR.
Chris | My Flickr | AirBrontosaurus.com | Peleng 8mm Fisheye writeup
Body
: Canon 5D
Lenses: Canon 24-105mm f/4 L | Canon MP-E 65mm Macro | Canon 85mm f/1.8 |
AirBrontosaurus is offline   Reply With Quote
Old 7th of August 2006 (Mon)   #3
lippy113
lippy113's Avatar
direst flash
partial metering
no diffusser
Old 7th of August 2006 (Mon)   #4
lippy113
lippy113's Avatar
same room 10 seconds earlier different settings have a look please... But taken with slower shutter speed but how can i guarantee they will always be like this ? I WANT TO TRY AND ADVOID A TRIPOD OR IS THIS NOT POSSIBLE
SHOOTING MODE AV
TV 1/20
AV 2.8
ISO 400
Focal Length 34mm
W/B Auto
HOW CAN TWO PICTURES TAKEN SO CLOSE APART BOTH WITH FLASH BE SO DIFFERENT
Old 7th of August 2006 (Mon)   #5
AirBrontosaurus
Well, your aperture in the second one was f/2.8 vs f/4 in the first one, which is 2 whole stops. Then, your shutterspeed went from 1/60th to 1/20th, which is 3 more stops. Basically, you let 5x as much light in the second one as you did in the first one.
Also, the first one used Av (aperture priority), which treats the flash as direct instead of fill, i think.
Also, when using a flash, shutterspeed will ONLY effect background exposure. So, since you used a higher aperture and shutterspeed in #1, the background exposure was cut 5 times, while the foreground exposure was kept realtively the same.
Try using the flash for fill instead of direct. That way, the camera will meter the subject, and the flash will compensate the background. You should also get much mroe even lighting that way.
Body
: Canon 5D
Old 7th of August 2006 (Mon)   #6
xepherys
xepherys's Avatar
As AB mentioned, the five stops is a huige difference, but hand holding at 1/20 is dangerous. You'll not usually get quite as shar of images. Using a lower aperature will let in more light. If you can get a fast lens (like an f/1.8) it will aid in this type of shot quite a bit. For ideal pictures, I'd recommend a tripod (I know, you odn't want to use one, but in low light, it's best if it's an option), a very wide aperature and a good long exposure at ISO100. You'll get less grainy shots that are more stable and more true to the environment you're shooting. In fact, depending on the existing shadows, you may not need a flash at all for that type of shot.
My Gear: EOS 7D .|. EF 85/1.8 .-. EF 24/2.8 .-. EF 70-200/4L .-. EF 24-70/2.8L .|.580EX-II
Website: www.jswilliamsphotography.com Blog: blog.jswilliamsphotography.com
Zenfolio Referal Code: TFY-NTD-77Z
xepherys is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Keeping dark backdrops (seamless) dark OviV Small Flash and Studio Lighting 13 1st of June 2007 (Fri) 15:47
Are these too dark? snooc People 14 28th of May 2007 (Mon) 12:25
selecting dark objects from dark backgrounds steve547 RAW, Post Processing and Printing 6 28th of December 2006 (Thu) 20:50
A Dark, Dark Day. Forget the Silver Lining. Lens Trashed. Belmondo Canon EOS Digital Cameras 40 18th of February 2004 (Wed) 04:51
