Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 22nd of August 2006 (Tue)   #1
PEACHMAN
PEACHMAN's Avatar
Default ISO; 300D vs 30D and 20D
I got some grainy photos shooting at ISO 800 this weekend and it has been brought to my attention that the 300D does not produce the same results at these ISO's as the 30D and I assume the 20D(?)...I thought they used the same processor ?? Antbody out there that can streighten me out on this??
20D
300D
Canon 18-55 kit lens
Canon 75-300 /4-5.6 III
Sigma 70-200 /2.8
Sigma 10-20
Tamron 28-75/ 2.8
420ex flash
550 ex flash
BG-E2 grip
Tripods
Monopod
The "eyes" have it !
http://peachfoto.com
PEACHMAN is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #2
Mikelangelo
Mikelangelo's Avatar
Default Re: ISO; 300D vs 30D and 20D
The 300D is a 6 megapixel CMOS procoessor. From what I understand, the 30/20Ds handle higher ISO settings much better. The 20D and 30D DO share the very same CMOS processor, tho'... so it should be virtually identical results with those cameras.
"An object at rest cannot be stopped."
http://www.mikelangelo.com/blog/
30D ::: 17-50 f/2.8 Tamron ::: 70-200 f/4.0L ::: 50 f/1.8
Mikelangelo is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #3
Steve Parr
should have taken his own advice
Steve Parr's Avatar
I used to shoot with the 300D but, when I got into concert photography, I needed something that would perform well at higher ISO's (800+). The 20D and 350 were comparable, but I went with the 20D, primarily, because it's physically bigger and fit my hands better.
In my experience, the 300D is downright offensive at an ISO over 400.
If a new body isn't something to consider, you could always go the Neat Image route (noise reduction software). I've had pretty good results with that...
Steve Parr is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #4
nitsch
30D/20D perform better than 300D. I'm with Steve, I don't like the results of the 300D above ISO400, however I quite happily use the 30D at ISO800. The 30D performs identically to the 20D AFAIK however the advantage of the 30D is that you can choose ISO in 1/3 stops - I like this as there are times when you need more than ISO400 but on the 20D you would be forced to leap a whole stop to ISO800 wheras on the 30D ISO500 and 640 are available and if they will suffice then the noise performance is better than pushing it to 800. HTH!
nitsch is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #5
PEACHMAN
PEACHMAN's Avatar
Well , I guess I'll be getting that 20D out a lot more and the 300D a lot less...Thanks for the confermation folks...And 1/3 stops of ISO in the 30D ? I guess that makes more sense than 2X stops...
20D
300D
Sigma 70-200 /2.8
Sigma 10-20
Tamron 28-75/ 2.8
420ex flash
550 ex flash
BG-E2 grip
Tripods
Monopod
Old 22nd of August 2006 (Tue)   #6
peterdoomen
peterdoomen's Avatar
Location: Lier, Flanders (northern, flemish speaking part of Belgium)
Yes, the 20D performs quite well in low light and high ISO.
(See for example the results of a show shooting I posted on http://photography-on-the.net/forum/...d.php?t=133041)
P.
Canon EOS 20D | Canon 70-200 f2.8L IS + Hoya UV Filter | Canon Extender 1.4x | Canon 50 f/1.8 | Canon 85 f/1.2L mk II | Tamron 17-35 f/2.8-f/4| Tamron 28-75 f/2.8 | Tokina 100 f/2.8 macro | Kenko extension tubes | Canon Speedlite 420 EX & Sto-fen Omnibounce| 80GB Flashtrax | Manfrotto Tripod 190 pro B & Joystick 322RC2 | Lowepro Micro Trekker 200
PDFs: Make money with ShutterStock - Make your own Tabletop Studio - Glass Buying Guide
My ShutterStock Gallery
peterdoomen is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #7
Tee Why
"Monkey's uncle"
Tee Why's Avatar
No, the 10d/300D use a Digic I processor and have the same IQ.
The 20D/30D uses a diff. sensor and digic II processor. The high ISO noise is a small bit lower.
Here is a noise comparison by dpr of 10D and 20D which should be the same as 300D vs a 30D.
http://www.dpreview.com/reviews/canoneos20d/page20.asp
There is some diff. at ISO 800 and up but I really don't think it's much.
Gallery: http://tomyi.smugmug.com/
Tee Why is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #8
mbellot
Not properly oriented
mbellot's Avatar
I've read numerous time that the 1/3 ISOs are "faked" in the 30D and you can get the same effect on the 20D with exposure compensation and some tweaking in PP (ISO500 would be ISO400 with -1/3EC pushed +1/3 in PP, assuming you're shooting RAW).
I've never seen any actual tests/data to back it up, but it makes sense.
mbellot is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #9
nitsch
Very true, but it's a hell of a lot less PP to be able to do it in camera!
You can use the term "faked" if you wish, but what you definately cannot say is that it is just the 1/3 stops in the 30D which are "faked". If you want to use the term "faked" then you must use that term for ALL ISO settings above the native ISO of the sensor on ALL digital cameras. Increasing the ISO in a digital camera is NOT the same as using different film speeds; an ISO400 film is actually twice as sensitive to light as an ISO200 film, however when you switch your digicam from ISO200 to ISO400 your CMOS/CCD has not changed in sensitivity, the signal from the sensor is merely being amplified - you can call this "faking" the ISO value if you wanted I guess, and you are right in saying that there is no reason why you can't do this in the RAW conversion rather than "in camera", but remember this is the same for every digital camera, not just the 30D! HTH!
Old 22nd of August 2006 (Tue)   #10
syntrix
syntrix's Avatar
I thought my 20D had the 1/3 stop option in the Cn menu. Hmmmm.
syntrix is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #11
adas
adas's Avatar
Yes, but only for aperture and shutter, not ISO.
adas is offline   Reply With Quote
Old 22nd of August 2006 (Tue)   #12
syntrix
syntrix's Avatar
Ahhh, that's right!
Old 22nd of August 2006 (Tue)   #13
mbellot
mbellot's Avatar
No argument at all, and if you're shooting jpeg its a big plus.
Its also nice since (I assume) you still have the +/-2 EC that the 20D has already. Though you could get into some interesting numerical twists... Is shooting at ISO500 with +2/3EC more or less noisy than ISO800 (and so on, ad nauseum).
Well, sort of.
My understanding was that the full stops actually changed analog multipliers (opamps) while the 1/3 stops were handled in the digital domain.
If the 30D actually adjusts the gain on the opamp in 1/3 stop increments then I would consider that "real" ISO. Doing it after the A/D conversion is what I thought was happening and why I called it "fake".
Old 22nd of August 2006 (Tue)   #14
Titus213
Titus213's Avatar
Peachman - I still use my 300D and don't mind using the higher ISO. I also use Neat Image Pro. The 20D does handle the higher ISO better IMO but the 300D is quite useable. I think the main trick is to get proper exposure as any under exposed image will show some noise. Here's a link to some interesting test results from DPReview. The 300D is a bit long in the tooth at this point so the comparisons are not with current equipment.
http://www.dpreview.com/reviews/canoneos300d/page13.asp
Dave
Perspiring photographer.
Titus213 is online now   Reply With Quote
Old 22nd of August 2006 (Tue)   #15
solinger
solinger's Avatar
Higher ISO gets grainy when you miss the exposure a little. My 300d is fine at higher ISO but I am not as picky about noise as some. I can try to dig up an 800 ISO shot I took right after I got my 300d that impressed me.
Sam
If I could tell the story in words, I wouldn't need to lug around a camera. ~Lewis Hine
solinger is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micron size 6.4 30D/20D/350D/300D pgulati Canon EOS Digital Cameras 4 28th of January 2007 (Sun) 18:55
WTB (UK) Spare 30D/20D/300D/10D US spec battery charger EOSAddict Classifieds: Buy 1 28th of March 2006 (Tue) 11:50
Compare iso of 30D and 20D Pida22 Canon EOS Digital Cameras 1 2nd of March 2006 (Thu) 08:09
ISO 1600 300D vs 20D Bill S Canon EOS Digital Cameras 19 16th of February 2006 (Thu) 18:28
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
