Reply
Thread Tools Display Modes
Old 24th of August 2006 (Thu)   #1
dr_who
Default Tamron 17-35mm + 28-75mm vs. Tamron 17~70mm or 17~50mm
I have Tamron 17-35mm and 28~75. I'm pretty happy with both of them. The 28~75 is send back for calibration for focusing problem, but if MF, it is very sharp. Now, as far as IQ is concerned, is 17~70mm or 17~50mm as sharp? I am thinking about replace the 2 lens with a single one because it is easier not to swap lens.
5D, 50mm F1.4, Sigma 24-70, EF 70-200mm F2.8 IS
dr_who is offline   Reply With Quote
Old 24th of August 2006 (Thu)   #2
Wilt
Wilt's Avatar
Default Re: Tamron 17-35mm + 28-75mm vs. Tamron 17~70mm or 17~50mm
The 17-50 is a very sharp lens...rivals the Canon 17-55. Pretty evenly divide the MTF performance according to photozone. Just remember the 17-50 won't give you the 50-75 range, if you're carrying only one lens (the 17-50)! I wish there was a Tamron 17-85 f/2.8 as a choice!
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 24th of August 2006 (Thu)   #3
Tee Why
"Monkey's uncle"
Tee Why's Avatar
I have the same lenses and am thinking about selling both for a Tokina 16-50 when it comes out if it's a good lens.
I think the 17-50 has a bit more CA and more light falloff, if I remeber correctly, the build quality is same though.
Photozoned has tested all excep the 17-35, Klaus removed it for some reason.
Gallery: http://tomyi.smugmug.com/
Tee Why is offline   Reply With Quote
Old 11th of March 2012 (Sun)   #4
Bennis
EDIT:
sorry for the thread dig, did not even look at the dates... silly me
Bennis is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Tamron 28-75mm VS Tamron 17-50mm ? toneepham Canon EF and EF-S Lenses 22 25th of June 2008 (Wed) 17:09
Sigma 28-70mm f/2.8 EX DG or Tamron 28-75mm f/2.8 XR Di LD? xzombiex Canon EF and EF-S Lenses 30 14th of March 2007 (Wed) 05:19
24-70mm 2.8 L versus Tamron 28-75mm 2.8 Alejandro Sandoval Canon EF and EF-S Lenses 63 1st of September 2006 (Fri) 14:54
Tamron 28-75mm vs. Sigma 24-70mm dr_who Canon EF and EF-S Lenses 20 20th of July 2006 (Thu) 13:56
Sigma AF 24-70mm f2.8 EX DG Vs Tamron SP AF 28-75mm f/2.8 XR Di LD Zeke Canon EF and EF-S Lenses 11 5th of October 2005 (Wed) 06:11
