#1 |
I recently purchased a Pro90 and I am considering a flash as my next purchase. Are there any recomendations as to what may be the best all round flash for the Pro90??
My sales rep recommends the 420EX because it is a better value than the 550EX. Also I like the idea of smaller hardware to carry around as my plan is to keep my gear bag as light weight and uncluttered as possible. Any suggestions?? James |
| sponsored links |
#2 |
If I have some spare money
Roel |
#3 |
Hi Roel,
I think I will get the 420, I agree that it is the best value. James |
| sponsored links |
#4 |
I agree that the 420EX is value for money and the size is not too big for the camera. However if you want to manually adjust the flash compensation, do consider the more costly 550EX.
#5 |
How can you be sure of a good lighting, if you do a manual adjustment?
#6 |
Part of the reason that I purchased the Pro90 is because it had TTL Metering for the flash as well.
Is there something where I may want to do a manual adjustment too?? |
#7 |
What are the differences between the 550EX and 420EX Speedlites? I can compare the specs, but I don't know what most of it means.
![]() I stole the specs from B&H (bhphotovideo.com) and put them on the following link for side-by-side comparison. 550vs420 Any interpretation of the specs, or general description of differences would be very helpful! |
#8 |
While I am not an expert in these flashes, I did just purchase the 420EX for my Pro90. My understanding of the main difference between it and the 550EX (other than price) is that the 550 has a more powerful flash and can "reach" farther than the 420EX. The 420EX also can only fire at full power in full manual "M" mode. The 550 can adjust its power even in M mode.
Even still I am very pleased with the 420EX. I can't believe the difference it makes in the quality of shots over the built in flash. Even though it was expensive ($185 US) it was probably the best accessory I have purchased because I take a lot of indoor shots. |
| Thread Tools | |
| Display Modes | |
| Non-Cannon Flash for PRO90 | pjr99 | Small Compact Digitals by Canon | 14 | 16th of November 2002 (Sat) 05:51 |
| problem with pro90 IS flash or is it something else!! | pramodbutte | General Photography Talk | 0 | 29th of September 2002 (Sun) 22:02 |
| External Flash for Pro90 | Teffy | Small Compact Digitals by Canon | 3 | 31st of October 2001 (Wed) 17:06 |
| Using Pro90 in studio to trigger flash | Rick | Small Compact Digitals by Canon | 2 | 7th of April 2001 (Sat) 13:28 |
