Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 31st of August 2006 (Thu)   #1
casp3r
casp3r's Avatar
Default Airshow advice
Hi there,
I'm going to another airshow this weekend and need some advice on how to get the correct exposure. I've taken some shots at shows over the summer and most of them have be under-exposed as can be see here - http://www.dalesplanes.co.uk/gallery...s.php?album=21. I never had problems before when I used my trusty old T90 with it's spot metering, but now I'm using a 350D with 70-300mm lense.
Any advice would be greatly appreciated.
Many thanks
Michael
casp3r is offline   Reply With Quote
Old 31st of August 2006 (Thu)   #2
GyRob
Default Re: Airshow advice
if you used that ground shot of the 2 hele's and set the camera to manul with thoes settings i.e apeture shutter speed you would be very close to the right exsposure but for inflight aim more for a faster shutter speed .
so next time take a shot like that and set that reading on manul as long as the light is the same it will be fine - take a shot and check then if you need to ajust exsposure.
Rob.
GyRob is offline   Reply With Quote
Old 31st of August 2006 (Thu)   #3
PhotosGuy
Moderator
PhotosGuy's Avatar
if you used that ground shot of the 2 hele's and set the camera to manul with thoes settings i.e apeture shutter speed you would be very close to the right exsposure...
I agree with that.
...but for inflight aim more for a faster shutter speed .
Yes for jets, but not with prop aircraft.
Posted by peacock: "I always try to shoot the prop plane @ less than 1/125..."
http://photography-on-the.net/forum/...d.php?t=209768
Posted by adamsti: General rule of thumb for props, 1/250 and slower for flying aircraft. 1/200 and 1/160 give very nice blur. For aircraft taxing 1/125 and slower. 1/60 is very good here. Obviously here you need a steady hand, but it can be done with practice.
Do a search for "Threads started by" Marauder61 for some inspiration. Or look at his gallery which has the exif data:
Marauder61
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 31st of August 2006 (Thu)   #4
casp3r
casp3r's Avatar
Many thanks for the replies. I'll experiment at the show and hopefully have some decent to post on Sunday evening
Old 31st of August 2006 (Thu)   #5
malla1962
malla1962's Avatar
This is what I do,I shoot TV all the time,partial or spot metering,jets 1/800 fast props 1/200 down to 1/125 for the slower or taxi shots,helicopters 1/80.I always add 2/3 to 1 full stop of exposure comp.
malla1962 is offline   Reply With Quote
Old 31st of August 2006 (Thu)   #6
peacock
peacock's Avatar
Looks like you have a nice line up for the Portrush show hope the weather hold out for you !
If you have enough memory its good to shoot raw so you have more control over exposure issues.
I use Tv mode and evaluative metering and dial in + 1 stop exposure compensation as standard and adjust as needed while chimping ( chimping is good , ignore the jokes)
enjoy the w/end ! I dont think you get many airshows over there
Edit to cut out what wansnt require to answer the question.
Just started populating a site with snaps @
www.3cakes.co.uk
peacock is offline   Reply With Quote
Old 1st of September 2006 (Fri)   #7
casp3r
casp3r's Avatar
Again many thanks for all the advice. As I've said I've alot of experimenting to do and I'll post some results on Sunday evening
This is only the second airshow in the whole of Ireland this year. Next year is shaping up to be a good year with the possiblity of 5
Old 2nd of September 2006 (Sat)   #8
Bobster
Bobster's Avatar
i always shoot manual and meter off of the grass/runway
Bobster is offline   Reply With Quote
Old 4th of September 2006 (Mon)   #9
casp3r
casp3r's Avatar
Well here's what happens when you get it wrong: Speed was 125 and I had over exposed by a stop - But I still like it
I think this one is spot on, even if it is flying away from me
Old 4th of September 2006 (Mon)   #10
peacock
peacock's Avatar
Apart from the brightness I like it too , looks like you shot it pretty much into the sun ? since the colours are low anyway have you though about darkening it and doing & B&W ?
second one looks nice , & exhaust haze too !
www.3cakes.co.uk
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Airshow Gear Advice gooble Transportation Talk 45 24th of April 2007 (Tue) 13:13
I need some advice on shooting an airshow. (newbie) carpenter Canon EOS Digital Cameras 10 14th of July 2006 (Fri) 15:17
Advice needed on using an IS Lens 4 airshow wardie General Photography Talk 4 7th of June 2006 (Wed) 23:10
Airshow shooting advice *Zwitter* Canon EOS Digital Cameras 6 17th of May 2005 (Tue) 09:55
Airshow lens advice ... any ideas ???? johneo Transportation Talk 15 17th of June 2004 (Thu) 18:36
