Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 1st of September 2006 (Fri)   #1
JuSlaughter
JuSlaughter's Avatar
Default Velbon Maxi F Tripod
Me again
When I bought my 350D, I bought a bundled set of kit with it too. I got a Lowepro Micro Trekker and a Velbon Ultra Maxi F.
What I want to know is has anyone had any issues with the Maxi F and images looking like the tripos moves/wobbles when taking a shot.
I don't think I've had a crisp shot taken off the tripod yet and I'm getting a little annoyed with it.
Canon 7D, Canon 5D, Canon 350D, 17-40mm F4, 24-105mm F4, 50mm F1.8, 100mm F2.8, 300mm F4, Sigma 10-20mm F5.6, 580EX II, 430 EX and a bagload of other stuff
website:www.phocusfotography.co.uk
JuSlaughter is offline   Reply With Quote
Old 2nd of September 2006 (Sat)   #2
crn3371
crn3371's Avatar
Default Re: Velbon Maxi F Tripod
A little more info, or a sample picture would help. How are you releasing the shutter? If you are using a cable release, or the timer, you shouldn't have any issues. If you are just manually pressing the shutter, then that's most likely your problem. The Velbon isn't the most robust of tripods, but it should handle your rig just fine.
crn3371 is offline   Reply With Quote
Old 3rd of September 2006 (Sun)   #3
JuSlaughter
I've just acquired an infrared remote so hopefully I should be OK from now on, thanks
Old 3rd of September 2006 (Sun)   #4
fluke
I have the same camera/tripod, and like was mentioned above, when I use my cable release it's fine
fluke is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Just bought Velbon maxi 343E tripod, need Quick release assembly-which to buy? OverRunWithSons Accessories & Storage 1 30th of November 2005 (Wed) 11:47
Velbon MAXi 343E condyk Accessories & Storage 5 28th of March 2005 (Mon) 22:08
Velbon MAXi tripods. Your thoughts? n00tch Accessories & Storage 6 30th of August 2004 (Mon) 21:03
Velbon Ultra Maxi getg3 Canon G-series Digital Cameras 1 10th of April 2003 (Thu) 12:49
