#1 |
So I've looked around at various stores and browsed the threads here and am still trying to figure out the best table top tripod. I'm looking for something that is very compact for transport, but is as flexible as possible. This will primarily be used with a Rebel XT + 17-85 EF-S lens.
The choices (unless I'm missing something): (1) The Bogen Table Top Digi 709. ![]() The advantages: Very well built. Nice ball head. Stable. The disadvantages: Sits very low on the table so you can't tilt the camera downward - not good for macro stuff. (2) The ProMaster T1. ![]() Advantages: Nice design. Flexible with a lot of uses - one thread on it mentions using it to stabilize a shot against the corner of a wall. Disadvantages: May be a bit unstable. (3) The Slik Mini Tripod. ![]() Advantages: The suction cup means you can stick it to things. Disdavantages: Kinda bulky looking (haven't seen it in person though). I'm not a big fan of the Slik leg extension tighteners. And not sure if the leg extension would be much use in the 'table top' use. So....any thoughts? |
| sponsored links |
#2 |
Yes...none of these....the novoflex microstativ....cheap, solid, fantastic build quality, I love mine...will even hold a 30D, grip and 300f4 (using the lens collar)
40 yrs in photography and still learning from all you good people...Thanks GEAR:-IXUS-60,Pana FT-1, Eos 7D, 50 f1.4, BG-E7, 24-70 L & 70-200 L , Gitzo Traveller, shedload of other bits/pieces & ORANGE Peli Cases |
#3 |
I Chimp, therefore I am
Checked the first 2 - no mention of load rating.
But it is stated for the bogen: "The Digi-Table-Top tripod was developed to maximize the superior imaging capabilities and versatility of new-generation, compact digital cameras. " Notice it does not say "DSLR" with heavy lense (and or flash , grip) Light duty Tripods tend to fail with SLRs on them. It will only be a small drop , but a drop nonetheless.
Dave http://www.flickr.com/photos/12185187@N00/sets/ 1DMK4, 1DSMK2, Canon and Sigma lenses |
| sponsored links |
#4 |
I use a Bogen 3007. I little pricey, but very well made. It breaks down for carry in a small pouch. I added an extra extension to add to its versatility. Highly recommended.
Canon 5D MkII | Canon 20D l Canon EF 50mm II f/1.8 l Canon EFS 17-85mm IS l Canon 85mm f/1.8 USM l Canon EF 70-200mm 2.8 L IS l Canon EF 24-105mm 4.0 L l Canon EF 17-40mm 4.0 L | Canon EF 100 2.8 MACRO l Canon 580EXII | Canon 580EX | Canon G3 l White Lightning lighting | and a whole boatload of other stuff |
#5 | |
Anyway, I ran down to the local camera shop and picked up the ProMaster T1 Max. The package is pretty poorly designed. I didn't even realize that it was a tripod until I looked closely. You'd think they could add a little picture. ![]() Here's a size comparison. Note the other downside: it doesn't fold into a straight shape. It has the angled section. But it does come with a little booty case. ![]() And firmly holding the XT and lens. Note the longer 'front' leg that stablizes the lens. Seems to work pretty well. ![]() I'm going to use it for a while and see if it works for my needs. If not, I've got 15 days to return it. Then maybe I'll try the Novaflex or Bogen 3007 mentioned above. Last edited by dbett : 2nd of September 2006 (Sat) at 13:36. |
#7 |
the rotating 3 leg trick like the one you got has been proven over the last 70 years by leitz........enjoy it
#8 | |
#9 |
Here is a review of several table tops. Based on these reviews I just bought the Giottos QU100 (should be here tomorrow). No review of Pro Master but maybe can give you some ideas in case you return yours.
http://www.the-gadgeteer.com/review/...ods_com_review |
#10 | |
Holy Schmokes! That's a lot of options - even if a number of them are only for compact point and shot cameras. Thanks for the link - great resource for folks. |
#11 |
Don't forget to look at the reallyrightstuff.com ground pod TP-243. It's a heavier sturdy model that can support around 50lbs. Some drawbacks but overall high quality.
85 f/1.2L II 100 f/2.8 macro MPE-65 f/2.8 |
#12 | |
#13 | |
#15 |
1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6 |
| Thread Tools | |
| Display Modes | |
| mini/table top tripod | azpix | Accessories & Storage | 6 | 23rd of April 2007 (Mon) 21:55 |
| What's the lightest table top tripod that will hold a 5D? | SunTsu | Accessories & Storage | 8 | 30th of January 2007 (Tue) 17:40 |
| Table top tripod | ungx0013 | Accessories & Storage | 3 | 11th of September 2006 (Mon) 22:55 |
| table top tripod opinions | alpha | Canon G-series Digital Cameras | 0 | 8th of February 2003 (Sat) 22:58 |
