Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 6th of September 2006 (Wed)   #1
mackb
mackb's Avatar
Default RAW converted straight to JPEG
If I shoot RAW, open the image and convert it to JPEG without making any corrections, will the image look the way it would have if it were taken in JPEG?
please don't tell me to search this topic or that "it's been asked before"......I'm sensitive
Billy
mackb is offline   Reply With Quote
Old 6th of September 2006 (Wed)   #2
HoRnYTuRbO
HoRnYTuRbO's Avatar
Default Re: RAW converted straight to JPEG
yah it should if u dont adjust anything
-Vinny
HoRnYTuRbO is offline   Reply With Quote
Old 6th of September 2006 (Wed)   #3
Tsmith
Formerly known as Bluedog_XT
Tsmith's Avatar
To be honest I've never actually saved my RAW's as jpeg but my thinking it would read the parameter used in the camera with the resulting image being that.
Give it a try and see _
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS
Canon PowerShot S95
MY PBASE GALLERY
Tsmith is offline   Reply With Quote
Old 6th of September 2006 (Wed)   #4
mackb
mackb's Avatar
OK......I'm dumb ........good idea!
Thanks........and just to be clear I did ask a legit question ,....I did not ask "what's better RAW or JPEG"....LOL
Billy
Old 6th of September 2006 (Wed)   #5
PacAce
Moderator
PacAce's Avatar
Depends on what raw converter you use. With Canon's or any 3rd party converter that uses the Canon raw converter API, yes, it will. With Photoshop or the rest of the other 3rd party converter, probably not.
...Leo
PacAce is offline   Reply With Quote
Old 6th of September 2006 (Wed)   #6
JaertX
JaertX's Avatar
it won't, actually. JPEGS have a little bit of sharpening, contrast and saturation adjustment, and noise reduction done to them...if you just process your RAW file and do nothing to it, it will probably look a little flat, unsharp, and noisey...may or may not be a drastic difference, depending on the shot.
(edit) one thing though...if your raw converter uses some "auto" adjustments to the file, it may tweak them to make up for it.
Jason - I use Canon and stuff
JaertX is offline   Reply With Quote
Old 6th of September 2006 (Wed)   #7
mackb
mackb's Avatar
I’ll continue to test this out and find what works best for me, but there does seem to be two different answers to something that should be straight forward……and by the way I use RSE .
Thanks for the help!
Billy
Old 6th of September 2006 (Wed)   #8
tim
Light Bringer
tim's Avatar
The camera usually applies sharpening, contrast, and saturation to the JPG, so unless your RAW convertor does that it won't be identical.
tim is offline   Reply With Quote
Old 6th of September 2006 (Wed)   #9
PacAce
Moderator
PacAce's Avatar
In case some of you weren't listening:
...Leo
Old 6th of September 2006 (Wed)   #10
JaertX
JaertX's Avatar
I guess I need to go back and try DPP again. I'm using Bibble now, occasionally ACR, and am very happy with them.
DPP left images very noisy compared to jpegs straight from the camera...but that is just anecdotal experience, not scientific fact. But from using it for a year or so before I bought Bibble and CS2, it didn't seem like Canon's RAW converter worked as well as it's in-camera JPEG converter.
Old 6th of September 2006 (Wed)   #11
Palladium
If I shoot RAW, open the image and convert it to JPEG without making any corrections, will the image look the way it would have if it were taken in JPEG?...
I'll add this into the discussion - depending upon what color space you have your camera set to capture in will also affect how your images look.
SRGB is a small color space that Adobe RGB - so less color range is captured if your using SRGB
For Sale: Gitzo GT3541LS Tripod http://photography-on-the.net/forum/....php?t=1234081
Palladium is offline   Reply With Quote
Old 7th of September 2006 (Thu)   #12
tim
Light Bringer
tim's Avatar
Did you say something PacAce? I wasn't listening
Old 7th of September 2006 (Thu)   #13
tzalman
Fatal attraction.
tzalman's Avatar
Sorry, but I think that needs a bit of modification. It is indeed true of Zoombrowser, but DPP produces a different result.
Elie
Elie / אלי
"If you presume to love something, you must love the process of it much more than you love the finished product." John Irving, 5/2012. "In theory there is no difference between practice and theory, but in practice there is." Yogi Berra
Site
tzalman is offline   Reply With Quote
Old 7th of September 2006 (Thu)   #14
tzalman
Fatal attraction.
tzalman's Avatar
there does seem to be two different answers to something that should be straight forward…….
Well, that's the nature of internet forums. There is no guarantee that anybody here knows anything.
Elie
Elie / אלי
Site
Old 7th of September 2006 (Thu)   #15
tim
Light Bringer
tim's Avatar
Elie
I don't know anything, I just repeat what i've read, got I high post now people think I know what i'm on about. Heh, that'll teach them for believing someone on the internet
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon 5D RAW+JPEG - JPEG Portrait Rotation Problem StephenJames Canon EOS Digital Cameras 10 23rd of May 2007 (Wed) 16:08
first time jpeg straight from camer jpalmer Birds 3 6th of May 2007 (Sun) 17:17
Photoshop JPEG from RAW Vs. In-Camera JPEG File Size ZRebel RAW, Post Processing and Printing 4 18th of December 2006 (Mon) 19:08
First converted RAW image.... chops Critique Corner 20 30th of November 2004 (Tue) 15:49
Why are my L JPEG pic sharper than Raw converted to Tif,JPEG dennykyser Canon EOS Digital Cameras 3 18th of January 2004 (Sun) 02:31
