Go Back   Canon Digital Photography Forums > Exhibit Engine > Version 1.0-1.5 discussion
Reply
Thread Tools Display Modes
Old 10th of September 2006 (Sun)   #1
superchief
Default IM not working
I'm having difficulty with IM with a relocated site. My original hosting company did not have IM installed so I resized manually. Now on new server I want to use IM.
The paths to IM convert and composite (/usr/bin) are reported as OK.
When I run a test on IM using the PHP Module Test Page I get no result image and no error either. Just blank space. Paths and settings seem to be correct per the documentation.
Any sugestions on where to look?
Thanks.
superchief is offline   Reply With Quote
Old 10th of September 2006 (Sun)   #2
JustJerk
JustJerk's Avatar
Location: A Long Island next to the "Greastest City in the World"
Default Re: IM not working
Have the same problem, please read the following thread.
http://photography-on-the.net/forum/...d.php?t=207091
Try to upload and resize something and see what type of error message you get in Messages box on the bottom. Match it up with mine from the thread above.
I've been lost and no one sent a search party for me.
JustJerk is offline   Reply With Quote
Old 10th of September 2006 (Sun)   #3
Pekka
El General Moderator
Pekka's Avatar
Try changing IM profile removal command, too.
This signature signifies my significance significantly
Photo Gallery
Pekka is offline   Reply With Quote
Old 10th of September 2006 (Sun)   #4
superchief
The profile removal command was the issue. Thanks to all!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How do I know if the IS is working? cbolton Canon EF and EF-S Lenses 14 7th of April 2007 (Sat) 19:51
s2 not working kawwauser Small Compact Digitals by Canon 12 21st of March 2007 (Wed) 13:34
Working with B/W Cfer4 Critique Corner 5 20th of December 2006 (Wed) 07:48
How can you tell if IS is working? backyarder1 Canon EF and EF-S Lenses 5 23rd of June 2006 (Fri) 13:30
working 4nR People 1 2nd of May 2005 (Mon) 16:23
