#1 |
Hi to all. I have been lurking around here quite long time already learning from your messages.
I am proud owner of Canon S3. This is my very first camera ever, and I'm loving it so far! But now it's time to get some filters and lenses for my baby. I'm going to buy - Raynox 52 mm adapter kit (incl. 52 mm polarizer and UV-filter). Info: http://www.digitaletc.com/go/item/2826 - Hoya HMC 52 mm ND4 and ND8 filters to cut light - for more special use Raynox Tele DCR-1540PR (adding some more power to zooming), 52 mm mounting threads, 67 mm front threads In future I'll probably buy also Raynox DCR-6600PRO Wide lens, but landscapes (and stuff like that) aren't really my cup of tea, so it can wait a little. Now I have one question (haha - one question? I have many, but with this one Google didn't help). Do I need to buy another 67 mm polarizer filter for tele lens or can I use 52 mm polarizer/uv filter in between of adapter and tele lens? Those 52 mm Raynox "kit filters" and ND filters have threads, so I believe in theory I can do that, but how about image quality and auto focus or other issues? (Sorry for my english and grammar, english is not my native language) PS: I attached two of my favourite pictures taken with this camera with. I haven't done any post processing with those pictures besides rezising. |
| sponsored links |
#2 |
Dang, you asked the same darn question that I just asked.....o well. I don't know if you can stick a filter in between lens and adapter, but I do know that if you go on ebay and type in "67 52 step down ring" you will get a step down ring that mounts on 67mm threads and has 52mm front threads, meaning that you would only have to pay for one filter and this ring. The rings are like 7 bucks, so it's not really a big deal. I would like to know if it's possible to stick a filter in between the lens and the adapter though.
P.S. Your grammar is better than most people's on online forums or in chat rooms. |
#3 |
Two points
1- you can use the filter between the adaptor and the lens - just remember the filter is not really made to support the weight and length of the lens. The torque on the filter could be a problem 2-Using the step down ring would work but would produce significant tunnel vision and decrease the wide zoom range of the unit. For example, with the TC in place zoom out to maximum width - after a while you will see the "tunnel" view. This would be show up sooner with the step down ring So if $ is high priority you can use the filter between lens and adaptor - just be careful |
| sponsored links |
#4 |
Canary and sonnyJ - thank you for you answers
Weight issue didn't cross my mind at all, so it was a good tip. I think that I first try with those 52 mm filters and if it doesn't work as expected, then buy 67 mm filters. Once again, thank you both. |
#5 | |
Canon and Sony Tele adapters are all 58 mm if you plan on a "Tele" so you won't need a step down ring, no fuss no muss! Example: Camera, Lens adapter (58mm), 58mm filters, Tele . You could then attach the Tele directly to the adapter and alleviate any strss problems (no filters). Changeling |
#6 |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
The added spacing of the filter may affect your focussing range, however. In particular, I'd expect a slight decrease in maximum focus distance (somewhat less than infinity), which you'd have to rely on DoF to make up for.
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
#7 | |
Also, a 67-52 step-down ring is really not a good idea. The Raynox adapter lenses are carefully designed to not reduce the amount of light reaching the camera.. using a filter that's 15mm smaller in diameter than the adapter's front element will compromise your camera's performance. Last edited by Pixel9ine : 4th of November 2006 (Sat) at 14:59. |
#8 | |
If I can do it that way, I would be able to use the polarizing filter with the main lens or with the .38 adaptor. I'm thinking that would be better than getting a 72mm polarizing filter to go on the end of the .38 adaptor because that shoots so wide (13mm equavalent) that I'm sure it would pick up the ring on the filter, giving me a 'tunnel' effect. I could just zoom in a touch to eliminate that but would then lose a bit of my wide angle ability. Any informed opinions on this would be most welcome. Thanks! |
#9 |
As far as I understood from various sources, the use of a filter (i specifically looked at circular polarizers) on the front of the wide angle lenses/converters can otherwise cause some vignetting (sp?) unless you speifically get the "thin" version (and even then some brands work better than others). I didn't see the same notation on telephoto lenses/converters, though I didn't check for a fact.
I I might point out though - the wide angle lens raynox HD-7000pro 0.7X has the front filter threads 82 mm as well as the Raynox DCR 2020 pro 2.2X so if you were ever inclined to such lenses/converters you might be able to purchase fewer filters. and if I may note something that no one has yet addressed - why are you getting the raynox filter set? My mom decided that she was going to get me the 58mm set and didn't know that I already got a hoya HMC circular polarizer. I like the effects of the one filter better than the set and the price difference at the same diameter was not that much. Just my 2 cents. |
#10 |
BTW, I like your raven
#11 |
I can only speak for the Canon teleconverter, but it can't be attached to a standard filter, as the threads on the filter are much too shallow to hold the converter lens. In fact, the threads on the lens won't even reach the ones on the filter. Even if a filter will fit between some lenses, I just don't think it's a good idea. Why not just put the filter where it belongs, which is on the end of the lens?
Gary Canon SX40, S100 and a Non Canon dSLR “Any darn fool can make something complex; it takes a genius to make something simple.”—Pete Seeger
#12 |
On these fixed lens cameras, you have to use an adaptor tube to attach anything. The lens itself has no threads, because it is retractable and any attachments would jam it as it when it retracts fully.
Thanks for the reply, though. Good advice for DSLR's. |
#13 |
Man, we know an adapter has to be used for filters etc! And make no mistake about it, this advice was not for SLR cameras, it was the Canon S3, which is an EVF camera!
#14 |
Ok ...I must have misunderstood. From the sound of things it seems like it will be a bad idea to try and screw an adaptor lens onto a filter. I'll heed that, and get two polarizing filters instead, a 52mm and a 72mm. I guess that's all I can do.
#15 |
Why would anyone take a simple thing and make it so difficult? Just screw the lenses and filters on to the dang adapter, 'cause boys and girls, that's what the adapter is for. Yeah it is!
| Thread Tools | |
| Display Modes | |
| Filter Lens adapter question | Jim Cob | Canon EF and EF-S Lenses | 2 | 8th of February 2007 (Thu) 12:39 |
| Tele Adapter + U/V Filter | quickben | Canon G-series Digital Cameras | 0 | 20th of April 2004 (Tue) 13:40 |
| lens/filter adapter | ftlmo | Small Compact Digitals by Canon | 2 | 28th of August 2003 (Thu) 13:45 |
| Lensmate 52mm adapter vs. Wide/Tele angle lens | G3guro | Canon G-series Digital Cameras | 4 | 19th of February 2003 (Wed) 21:27 |
