| sponsored links |
Thread Tools | Display Modes |
#1 |
i have a sigma 10-20mm and i always shoot with the polarizing filter on.
i have recently also been shooting with the lens hood on as well but now i cant twist the polarizing filter around because of the lens hood. Is there any way around this? or do you have the adjust the polarizing filter then put the lens hood on?? seems abit crappy! if anyone could help that would be great
5D Mark II || 550 D || 350 D || Canon 17-40L || Canon 24-70L || Canon 50 1.4 || Canon 70-200L IS 2.8 || 580 EX Speedlight || 480 EX speedlight x2 || Manfrotto 190CXPro3 + 488 RC2 || Cybersyncs Flickr |
| sponsored links |
#2 |
Africa's #1 Tour Guide
Well you could leave the hood off or you could leave the CP off. Otherwise, you are stuck. If I use a CP, which I don't much because not usually necessary, I just leave the hood off. You are losing light using a CP. Dunno why you want to use it all the time.
Now full! Great African Photo Safari 2013 - Kruger National Park, South Africa click |
#3 |
ahhh ok
so you use one or the other ![]()
| sponsored links |
#4 |
Practically, that is usually the case but it depends on the lens. I can use it on my 17-40mm and used one on my ex 12-24mm Tokina, but the hoods make access easy with those two. It might be worth shooting with it on and then off and see where it makes a difference. After all, if you not getting much difference, or a difference that makes a difference, most of the time then you are losing light for no good reason.
| Thread Tools | |
| Display Modes | |
| Best polarizing filter for Canon 17-40 lens | JAB1 | Accessories & Storage | 16 | 28th of March 2009 (Sat) 18:50 |
| Polarizing Filter and Lens Hood | caldgrp | Canon EOS Digital Cameras | 3 | 2nd of August 2005 (Tue) 15:07 |
| ND Filter and Circular Polarizing Lens | DCampo | Canon G-series Digital Cameras | 8 | 14th of June 2004 (Mon) 11:27 |
| Difference b/w Polarizing filter and CIRCULAR polarizing fil | taltalita | Canon G-series Digital Cameras | 31 | 27th of May 2003 (Tue) 23:11 |
