Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 23rd of February 2002 (Sat)   #1
Sachle
Default Compression
If I take pictures with the highest resolution and finest compression and later want to send the picture over the internet, is there a way to resave or copy the file with less size?
Sachle is offline   Reply With Quote
Old 26th of February 2002 (Tue)   #2
soumya63
Default Re: Compression
I use the following technique
1) Open the highest resolution picture in photoshop.
2) Save it using Genuine Fractal format.
3) Reopen the Genuine Fractal file and specify the image size. Generally I select 600 pixel as the width of a landscape picture and the height gets scaled accordingly.
4) Now select Save for web in Photoshop.
5) Select quality medium and save it as JPG file.
Normally a 18MB Tiff can be reduced to 30 to 50KB size in the above method.
If you do not have Genuine Fractal, you may use Photoshop Image resize with resample checked on. Otherwise you can download of the free Phtoshop action from Fred Mirenda's site.
Hope this helps.
Moreover, for vieweing on monitor you require only 72 dpi resolution. So if you save it for web, it will do that and your file size will be smaller.
soumya63 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Which compression should I use? Chrisku13 Small Compact Digitals by Canon 11 4th of February 2007 (Sun) 09:47
Compression Anthony McAvoy Still Life, B/W & Experimental 4 18th of November 2006 (Sat) 11:21
Compression vetkrazy Sports 4 1st of September 2006 (Fri) 00:48
Compression benth Canon G-series Digital Cameras 1 11th of June 2002 (Tue) 16:14
Compression bgmapes Small Compact Digitals by Canon 1 17th of April 2002 (Wed) 13:15
