Reply
Thread Tools Display Modes
Old 22nd of December 2003 (Mon)   #1
stub
Default Wide angle lenses for G2
I have just taken delivery of a wide angle conversion lense for G2. I ordered the WC-DC58 but have been sent the WC-DC58N. The supplier is telling me that this is approved by Canon for use with the G2 and gives a magnification of 0.7. Can anyone tell me if this is correct. It seems rather too large for the body. Please help.
stub is offline   Reply With Quote
Old 29th of December 2003 (Mon)   #2
pgparlee
Default Re: Wide angle lenses for G2
Hmmm. As I understand it, the Wide Converter WC-DC58N is .8x for the G3 or G5 only, and specifically requires a LA-DC58B conversion lens adaptor. The WCDC58 is .7x and is for the G1 and G2 with the LA-DC58 lens adaptor.
Since different thread sizes are involved in lenses and filters you might want to use, and step rings to accomodate them, I suggest you get someone who knows more about it to comment on the compatibility issues. Good luck.
- Paul N-ONT
pgparlee is offline   Reply With Quote
Old 1st of January 2004 (Thu)   #3
bfaust
I'm not sure but I think you can use either lens on the g2. Go into a local camera store and see if it works. I think they are both screw on 58 mm mounts. That would be the only problem. Search the archive on this sight because I think this has been answered about a year ago.
bfaust is offline   Reply With Quote
Old 12th of January 2004 (Mon)   #4
stub
Default
Thanks for the replies. The saga continues....
I finally got the right adaptor, the LA-DC58, for the G2. The wide converter WC-DC58N for the later models of the camera does indeed fit on the threads onto the camera body. However, I am not at all happy with the results. There is a very significant amount of blurring with the converter added on. So much so that the image quality is so degraded I wouln't want to use it! I'm planning to send it back to the shop and try the original one for the G2.
What degree of image quality loss should I expect with the conversion lens? Is there some incompatibility here with focal lengths or something?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wide angle lenses ShotByTom Weddings and Other Family Events 4 20th of May 2007 (Sun) 10:07
Wide angle lenses mknabster Canon G-series Digital Cameras 1 18th of September 2005 (Sun) 18:30
Which one of those wide-angle lenses? vvizard Canon EOS Digital Cameras 12 10th of November 2003 (Mon) 11:04
Please, Can someone help on wide angle lenses for G2 emaildbk Canon G-series Digital Cameras 0 9th of February 2002 (Sat) 13:13
wide angle lenses emaildbk Canon G-series Digital Cameras 0 6th of February 2002 (Wed) 22:06
