#1 |
Is it possible to set the 580EX in manual mode while using the ST-E2 to trigger it? I have searched for hours and cannot find any info on doing this. I don't see why it couldn't but can't figure out how! Thank you in advance for the help
Canon 5d with 35mm 1.4L, 24-70mm 2.8L and 135mm 2.0L My site: http://www.flickr.com/photos/incendy |
| sponsored links |
#2 |
Moderator
Yes it is. Just set the power level on the flash itself and make sure that the channels are set the same on both units.
...Leo |
#3 | |
Thank you PacAce! The problem is when I set it to slave I can't set the power. I know I am missing something easy here, but I just can't figure it out and the ettl light on the st-e2 won't go off no matter what
| sponsored links |
#4 |
Moderator
Put the flash to Slave mode. Then press and hold the mode button. "ETTL" will change to a flashing "M" indicating that it's now in manual mode.
...Leo |
#5 |
ok, I feel really stupid now, but you are awesome! thank you
#6 |
Moderator
No need to feel stupid. Some things on the flash, and the camera I might add, just aren't intuitive enough, and setting the flash to manual mode in Slave mode is one of them.
Why they didn't just make it so that you can simply press the mode button like you can in normal mode to manual is beyond my comprehension.
...Leo |
#7 |
Thanks again PacAce, I had so much fun playing with manual mode today. Feels so good to be able to use science again instead of praying to the ettl gods=D Of course the 420 is still an issue, but I found using ratios it works ok as a backlight! Now I just need one more light for hair and I will be happy! I am starting to think I would like a strobe to use with a sofbox and then use the 580 as the hairlight, but I don't have a studio and am afraid of the portability
| Thread Tools | |
| Display Modes | |
| Can ST-2E trigger 580ex in manual mode? | StealthLude | Small Flash and Studio Lighting | 7 | 10th of November 2006 (Fri) 08:18 |
| 580EX with Wireless in Manual Mode? | MagikTrik | Small Flash and Studio Lighting | 2 | 24th of July 2006 (Mon) 15:32 |
| Using the 580EX and 550EX flashes in manual mode | PacAce | Small Flash and Studio Lighting | 20 | 14th of March 2006 (Tue) 12:22 |
| manual mode on 580ex | nino_zeke | Small Flash and Studio Lighting | 11 | 10th of March 2006 (Fri) 11:49 |
| 580ex and 420ex manual mode help! | underground | Small Flash and Studio Lighting | 5 | 28th of December 2005 (Wed) 13:34 |
