#1 |
I am now tempted to buy an External Flash after looking at other Pro's ... Does it make a big big difference in photography?
Canon Digital Rebel XT, EF 50mm f/1.4 USM, EF 17-40mm f/4L USM, EF 100mm f/2.8 Macro USM Aikiphoto-Yake 3 strobes powerful 510w/s strobes lighting kit Sekonic L-358 Flashmeter, LowePro CompuTrekker AW |
| sponsored links |
#2 |
"Worth" is a relative concept.
It could help you to improve your pictures, though don't automatically assume that having the top of range flash will make your pictures better. Having an external flash is only half the story, learning how to use it is the other.
Canon 5D + Grip | 85mm L f/1.2 | 17-40mm L f/4.0 | 24-70mm L f/2.8 | 70-200mm f/2.8 L IS | Speedlite 580EX & 430EX | Manfrotto 190Pro + 488RC2 ephemeral.smugmug.com |
#3 | |
Don't get pissy with me
And knowing when to use flash and when not to use it is just as important as knowing how to use it.
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid! |
| sponsored links |
#4 |
I could not get the photos of strippers that I have to without a flash.
They flash at me so I flash at them! On a lighter note, any action photos in low light eg: drag racing,dancing girls etc. If you want to freeze the action, a good flash is needed. The camera flash just won't cut it. Not to mention some really cool effects you can get by playing around with second curtain sinc etc. Sounds like a battery pack to me. Never needed one. I get all the power I need from duracells.(never have let me down) for hundreds of pics. |
#5 |
Not to start a debate, but those packs are good for more than longevity...they make recycle times a LOT faster too.
#6 |
If you’re willing to put some time into reading and practicing flash photography, it can open a completely new door for you. For me, it’s much more about learning to control the light with the help of flash, than just creating light with a flash
Stefan 5D, 5D, 40D + 17-40L, 24-70L, 70-200L, 50/1.4, 85/1.8, 100L Macro and some other stuff. flickr, 5∞px |
#7 |
Master Flasher
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#8 |
"Slight breach of etiquette"
simply buy one you will not regret it.
Computers blur the boundaries... We are being released from the suddenness of photography, the suddenness of the shutter
#9 |
Depends what you shoot. For me, most indoor situations require flash. It's also a life-saver from direct flash.
#10 |
One huge advantage of external flash is that you can tilt and swivel the flash head, so that the light can come to the subject from the side or the top, instead of head-on. This gives you a level of control over the image that you'll never have with a built-in flash. For instance, you can turn the flash 90 degrees to the side and bounce the flash off of a wall or a reflector and get a strongly directional light, or point the flash at the ceiling and get an overhead lighting effect.
#11 |
I think something needs to be clarified first before we recommend OP blowing $200+ on a good flash unit:
Do you shoot with flash a lot now? Or does everything you do involve natural light? I would say if you do a LOT of onboard flash shooting (or any really), then yes an external flash would be most beneficial - it would improve your results dramatically. If you not use flash, and/or absolutely hate the look of it, then you can save your pennies at least for now, unless you want to begin experimenting right away. My 2 cents.
#12 |
Daddy Of The Crop
All I can say is I am very happy with my flash. I am learning a lot with it still...
5D3 | 35L | 50 1.4 | 85L II | 100L | 135L | 24-70L II | 70-200 2.8L IS II |
#13 | |
#14 | |
#15 | |
I love the pun!
Canon 24-105 L IS USM, Canon 70-200L f4 IS USM Canon 400mm L f5.6 Canon 7D, Canon 1.4 TCII Canon 10-22 Canon 420EX speedlite, Canon G1x |
| Thread Tools | |
| Display Modes | |
| How many of you use an external flash? | breakdown | General Photography Talk | 5 | 10th of March 2007 (Sat) 05:18 |
| I just bought a G6 - is getting an external flash worth the $$$ | Johnny Morales | Canon G-series Digital Cameras | 14 | 7th of May 2005 (Sat) 04:10 |
| S200 External Flash Sunpak Digital Flash Adaptor | Soyboy | Small Compact Digitals by Canon | 0 | 27th of September 2004 (Mon) 18:36 |
| Using built-in flash with external flash? | SC300T | Canon G-series Digital Cameras | 9 | 12th of November 2003 (Wed) 02:41 |
| External Flash and the G3 | bejiboys | Canon G-series Digital Cameras | 1 | 20th of March 2003 (Thu) 12:55 |
