Go Back   Canon Digital Photography Forums > Exhibit Engine > EE 2 Bugs
Reply
Thread Tools Display Modes
Old 4th of October 2006 (Wed)   #1
gillyworld
gillyworld's Avatar
Default snippets not working in EE2.0?
I use snippets in my home page which now doesn't work. I cant even get the snippetdemo.php to work. Heres what I get from snippetdemo
Exhibit Engine SNIPPETS demo
IMPORTANT SECURITY NOTE ABOUT SNIPPETS:
Depending on how your PHP was installed, snippets can be called from external sites, too. If you want to prohibit that, or restrict snippets to specific site(s), insert the line
if (trim($_SERVER["REMOTE_ADDR"]) != "127.0.0.1") { print "ip "; print $_SERVER["REMOTE_ADDR"] . " not allowed."; exit; }
(where 127.0.0.1 is the IP you want to allow, e.g. your server's real IP) to the beginning of the snippets.php after first <?php line . To allow several IP's, reuse that line of code.
NOTE that this method is not a foolproof because experienced hackers can forge IPs. If you need to ensure that snippets can not be called at all (for sake of resource usage and bandwidth), delete snippets.php from EE folder. If you want to ensure that only you can call the snippets, rename snippets.php to something that you know, e.g. HSJdkkdsk877823987321237871.php (it's an example, please don't use that!) and use that file.
Snippets work in EE 2.0 with public view only (no user login). 10 LATEST GALLERIES
$get = "latest_galleries";
$amount = "10";
$exhibition = "";
$thumbsize = "";
$viewas = "";
$includecategory = "";
$excludecategory = "";
$thumbclass = "";
$linkclass = "";
include("./snippets.php");
ip 86.129.220.185 not allowed.
Alan
To call someone incompetent is unfair to those of us who are....
gillyworld is offline   Reply With Quote
Old 4th of October 2006 (Wed)   #2
Pekka
El General Moderator
Pekka's Avatar
Default Re: snippets not working in EE2.0?
It's the IP filter. In snippets.php remove lines
PHP Code:
if (trim(@$_SERVER["REMOTE_ADDR"]) != "127.0.0.1") {
    print
"<br />ip ";
    print @
    exit;
Does this help?
This signature signifies my significance significantly
Photo Gallery
Pekka is offline   Reply With Quote
Old 4th of October 2006 (Wed)   #3
gillyworld
gillyworld's Avatar
PHP Code:
    print
"<br />ip ";
    print @
    exit;
Does this help?
Yes, works fine now thanks Pekka. Hope your concert goes well!
Alan
Old 4th of October 2006 (Wed)   #4
gillyworld
gillyworld's Avatar
I may have been a bit hasty, snippets produces the thumbnails ok, but the links are wrong when you click on the thumbs. Can't quite figure out why.
A couple of other minor issues
1. IF you opt not to use a Photo frame around a picture, then the options to select small, medium or large images are hidden from view
2. My default picture size is medium, but the default displayed is always small. Where do I say what is the default? I thought it was in the Paths?
Alan
Old 4th of October 2006 (Wed)   #5
Pekka
Pekka's Avatar
I'll look into that.
This is purely a default template design choice. The size list by name ($sizemenu_text_html) is placed inside (or rather over) the frame DIV in default template. I like it that way it is not obtrusive, and I use passepartout frames. You can move it out from there, or use variable $sizemenu_html to print the old style dropdown menu anywhere.
Path editor default size selection is gone in EE 2. The default size is now chosen by pixels in basecode/SETUP_settings.php, and also explained there
PHP Code:
// default photo size served. Value is in pixels.
// "800" means the default size is a photo where all sides are smaller than or equal to 800 pixels.
// "0" means smallest available
// "99999" means largest available
// THIS SETTING HAS NO EFFECT (RANDOM RESULT) UNLESS PHOTO SIZES ARE STORED IN DATABASE.
$s_default_size "0"
Photo Gallery
Old 4th of October 2006 (Wed)   #6
wkitty42
wkitty42's Avatar
eeewwwooo... is snippets not set up for "simple inclusion" as i did before with the v1.5 snippets stuff? i don't really like to have my server using up bandwidth back to itself for functions that can be better "served" internally...
[time passes]
in looking back at what i did here, i see that i took the ee_print_thumbs function and placed it into an include file and did a @require_once on it and there was a rather "large" mod/bugfix to handle a couple of special cases where $exhibition wasn't set properly plus a few other seemingly minor fixes... however, at this point, i'm not sure what, exactly, it was that i did to switch from "url_fopen" (is that right?) usage to simple local include usage...
in any case, since i've not yet gotten ee2 installed and i don't currently use snippets anywhere other than some demo and playing around stuff, i guess i won't worry about it too much until after i get things in place and have a working ee2 gallery
wkitty42 is offline   Reply With Quote
Old 5th of October 2006 (Thu)   #7
gillyworld
gillyworld's Avatar
[quote=Pekka;2077710]
quote]
The problem occurs when the page using snippets is not in the same directory as the snippets code. I think in 1.5 this used a parm set in misc settings.
Alan
Old 5th of October 2006 (Thu)   #8
wkitty42
wkitty42's Avatar
actually, the way i did it was to place it in the php shared libraries directory...
[time passes]
in my .htaccess file, i have something similar to the following
Code:
php_value include_path ".;\shared\includes;\www\exhibits"
the above line tells php to look in the current directory (the .), \shared\includes, and \www\exhibits on the current drive... i have the snippets code php files located in the "includes" directory...
this allows me to call that code from anywhere... of course, with exhibit engine, i also include the "prerequesite" (?) include paths so that the snippets libraries can also locate the ee data and code that they need to work properly...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Adding UDM4 to EE2 Pekka EE 2 Styles 15 7th of June 2008 (Sat) 13:24
Enhanced EE2 updater MMCM EE 2 Coding 0 6th of May 2007 (Sun) 08:46
EE2 Fresh Install SuperFly EE 2 Installation 21 8th of March 2007 (Thu) 20:07
EE2 Upload Problem Pete EE 2 Installation 1 5th of March 2007 (Mon) 03:58
EE2 Admin Logon UweB EE 2 Installation 17 15th of December 2006 (Fri) 18:14
