Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 2nd of March 2002 (Sat)   #1
Ekliptix
Default Canon S100 Battery?
My battrey sucks. Are there any other compatable batteries that I can buy to replace the ons that came with the camera?
Thanks.
Ekliptix is offline   Reply With Quote
Old 7th of March 2002 (Thu)   #2
Tom Brown
Default Re: Canon S100 Battery?
My best friend has an S100 and I have an S110. Our batteries last pretty well. How long are you getting out of a charge?
Don't forget that you can turn your LCD off and use the optical viewfinder. That will add a ton of life to your battery. You'll probably want to go to the LCD for anything closer than about 10 feet, though.
This isn't a particularly valid thing to do but I'll take a wild guess at some of my battery capacity numbers. I could probably take about 200 non-flash pictures with the LCD off. It would be around 75 flash pictures with the LCD off. I'd guess it to be around 40 flash shots with the LCD on and not being too generous with the time the camera is on and not shooting. If I'm doing a lot of viewing and looking at the LCD for long periods of time to compose a frame, or whatever, the battery life goes way down. I've gotten as few as 15 shots out of it but it could just as easily been 0 shots.
If you're comfortable with the camera, the standard lithium battery should last quite nicely. I haven't had very good luck cycling lithium batteries but you might try that. Just kill it right down in the camera and then charge it right up. It may help to do that 3 or 4 times.
Regards,
Tom Brown
Tom Brown is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon S100 shuts off immediately jumunius Small Compact Digitals by Canon 6 9th of December 2006 (Sat) 18:05
Canon S100 CF Card Error manda102 Small Compact Digitals by Canon 3 12th of September 2006 (Tue) 15:17
Need help with my Canon S100 for work.... PureForensic Small Compact Digitals by Canon 1 5th of December 2002 (Thu) 20:33
Corrupt files from Canon Powershot S100 Simon RAW, Post Processing and Printing 0 12th of November 2001 (Mon) 19:11
