Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 1st of January 2004 (Thu)   #1
roberthd
Default A70 manual mode vs aperture priority
Thx to all for feedback. I apologize for all the posts but I am really using the A70 a lot and am looking for some help in order to really understand all its options.
Here's the dilemma. Today I took several flash shots in aperture priority mode. I noted the shutter speed chosen by this mode. The shot seemed OK. But when I switched to manual mode and dialed in the exact same aperture and shutter speed used in aperture priority mode, the camera gave me the red -1 1/2 warning, which means I am underexposed by 1.5 stops. How can this be?
thx
roberthd is offline   Reply With Quote
Old 2nd of January 2004 (Fri)   #2
stduc
Default Re: A70 manual mode vs aperture priority
Did you have the flash turned on?
Did you have the correct flash power set?
stduc is offline   Reply With Quote
Old 2nd of January 2004 (Fri)   #3
roberthd
Thx for the reply...yes, I double-checked everything, incl. the flash power...which was at full. And it was turned on. I think I will reset the entire system to factory defaults and try again...don't know what else to do.
thx
Old 2nd of January 2004 (Fri)   #4
stopbath
The camera will measure available light when measuring in manual. It will not add in the potential flash output.
Nothing is wrong with your camera.
stopbath is offline   Reply With Quote
Old 2nd of January 2004 (Fri)   #5
roberthd
Thanks...I never thought of that, great answer, I appreciate it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
20D - Manual Mode: I can't adjust the Aperture - Why? gmaize Canon EOS Digital Cameras 28 5th of November 2010 (Fri) 15:45
Manual Mode and aperture setting DRAGUI99 Canon EOS Digital Cameras 7 18th of February 2007 (Sun) 17:46
need help.. setting aperture in manual mode Hossam Canon EOS Digital Cameras 11 10th of November 2006 (Fri) 10:01
Aperture Priority on the 5D ianprovofoto Canon EOS Digital Cameras 4 18th of July 2006 (Tue) 22:48
Manual, aperture or shutter priority Scrappinmamacita General Photography Talk 59 16th of January 2006 (Mon) 23:36
