Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 9th of October 2006 (Mon)   #1
incendy
incendy's Avatar
Default ST-E2, 580EX M mode and 420ex with ratio?
If I have the 580ex on channel A and set to Manual Mode and the 420ex on channel B will my ratios on the st-e2 still work? Basically trying to come up with some way to use the 420ex with my other lights without it doing its own thing
Canon 5d with 35mm 1.4L, 24-70mm 2.8L and 135mm 2.0L
My site: http://www.flickr.com/photos/incendy
incendy is offline   Reply With Quote
Old 11th of October 2006 (Wed)   #2
incendy
incendy's Avatar
Default Re: ST-E2, 580EX M mode and 420ex with ratio?
ok, in theory this sounds like it would work, but it doesn't The first couple of tests seems to work cause I had the main light with the right power and the ettl was fill, but then I purposely set the main light to underexpose by a large margin and ettl still kicked in on the 420 to expose the shot. Time to sell the 420
Old 11th of October 2006 (Wed)   #3
In2Photos
Moderator, Archive Keeper
In2Photos's Avatar
Yeah, the 420 has no manual mode so won't work good for this application. Step up to the 430 or another 580.
In2Photos is offline   Reply With Quote
Old 11th of October 2006 (Wed)   #4
PacAce
Moderator
PacAce's Avatar
I don't have the ST-E2 so I can't tell you for sure that it should work, but when I use my 580EX as the master, without firing the flash and in essence emulating the ST-E2, and my 550EX as Slave A set to manual mode and my 420EX as Slave B in, of course, ETTL mode, I can set the A:B ratio to whatever I like and the 420EX fires accordingly. I would imagine that the combo should work the same way with the ST-E2, too.
...Leo
PacAce is online now   Reply With Quote
Old 11th of October 2006 (Wed)   #5
PacAce
Moderator
PacAce's Avatar
Let me expound on my previous post. When you set a 580EX to manual mode and power is adjusted on the slave flash unit, the only function the master provides is flash synchronization. So, when you have the A:B ratio set and the other flash in the combo is set to ETTL mode as is the case with the 420EX, the output of the ETTL flash (the 420EX) will be determined by the ratio setting based on what the Group A flash would have put out if it were also in ETTL mode also. In other words, the 420EX output is not going to be based on what the 580EX is set to in manual mode since the master has no way of knowing what that is (a slave in manual mode does not fire a preflash).
If you were to use another 580EX as the master, like I did earlier, then you will be able to control the manual output setting of another 580EX or 550EX slave (which are in ETTL mode) from the master itself by setting the master to manual mode. However, if you do that, then the 420EX won't work in this combo because the 420EX does not have manual mode capability. It'll only work when the ST-E2 is used or the flash used as the master is set to ETTL mode.
...Leo
Old 11th of October 2006 (Wed)   #6
incendy
incendy's Avatar
Thank you PacAce! That clears it up for me really well. I need to get rid of the 420, was just trying to use it cause I am trying to save money for other things, but I am finding for what I want to do it just doesn't really work for me
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
580ex slave/master ratio question shutterfiend Small Flash and Studio Lighting 2 29th of June 2007 (Fri) 09:04
Flash Comp & Ratio Question (580EX) Eoseni Small Flash and Studio Lighting 11 18th of May 2007 (Fri) 09:12
580ex and 420ex manual mode help! underground Small Flash and Studio Lighting 5 28th of December 2005 (Wed) 13:34
Question about automatic mode in 550EX/420EX/580EX Henry Low Small Flash and Studio Lighting 4 7th of March 2005 (Mon) 16:54
Flash Ratio 550EX / 420EX Vegas Poboy Small Flash and Studio Lighting 7 24th of March 2004 (Wed) 12:00
