Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 14th of October 2006 (Sat)   #1
Nekkid
Default How can I tell if PS is using the right ICC profile?
Hi all,
I just got my Spyder 2 Express and installed it and ran the software, which seemed to work ok, although it came up with some message at the end, the contents of which I've now forgotten. Anyway, how can I check if PS elements is using the profile that I just created?
Thanks!
Canon 20D
EF-S 17-85
EF 50 f1.8
EF 50 f1.4
EF 70-200 f2.8L (Yay!)
Hoya Circular Polarizers
Speedlight 430 EX
Manfroto ball head something-or-other
Elinchrom Style 400 x2
Stands, brollies, softbox and 500 miles of cable.
Nekkid is offline   Reply With Quote
Old 14th of October 2006 (Sat)   #2
matthewlrigdon
Default Re: How can I tell if PS is using the right ICC profile?
It would be your OS that uses the profile that's created. In Windows, go into your display settings and I believe you have to check under the Advanced settings in the last tab (Settings?) to double-check that Windows has loaded this profile as your monitor profile.
In Mac, System Preferences > Display > Color
matthewlrigdon is offline   Reply With Quote
Old 14th of October 2006 (Sat)   #3
Nekkid
Cracking, thanks for that, it appears to be using the one I just created.
Cheers!
Canon 20D
EF-S 17-85
EF 50 f1.8
EF 50 f1.4
Speedlight 430 EX
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
icc profile anybody? blue_max RAW, Post Processing and Printing 3 20th of September 2005 (Tue) 17:37
G5 ICC profile? phil1 Canon G-series Digital Cameras 0 30th of September 2003 (Tue) 11:47
G3 ICC profile? pukkita Canon G-series Digital Cameras 2 8th of June 2003 (Sun) 16:15
G3 ICC Profile TibbySF Canon G-series Digital Cameras 4 29th of December 2002 (Sun) 13:30
ICC Profile for G2 ljhrusovsky Canon G-series Digital Cameras 1 3rd of May 2002 (Fri) 09:52
