#1 |
anybody got rumors or any info on this? im on the edge of buying the lens but fear an update may be close....
| sponsored links |
#2 |
obsolete as of this post
This particular lens just got updated relatively recently from the 28-70/2.8L and with the 24-105/4 I wouldn't anticipate an update any time in the next 2-4 years. Unless the rumor of the 2X format are true then all bets are off.
lenses don't get updated anywhere near as fast as cameras.
"Save the model, Save the camera, The Photographer can be repaired" www.longwatcher.com 1DsMkIII as primary camera with f2.8L zooms and the 85L http://www.longwatcher.com/photoequipment.htm |
#3 | |
and do you think its still wise to purchase the 24-70 now? |
| sponsored links |
#4 |
Now is a good time to purchase the 24-70/2.8L
While eventually they may add IS to the 24-70/2.8L I suspect it will be at least a year or two. Also take into account that there will be a small drop in quality with IS (probably not noticeable, but there). There have been no rumors of a 24-70 upgrade in the works and the earliest one would be likely to occurr would be PMA, so you will get at least 5-6 months of use out of yours before a new lens comes out. That is a pretty good bet. As to the 2X format: It is a rumor that Canon is planing on releasing a camera with a double 35mm format sensor (using two sensors side-by-side - long side together). To compete with medium format cameras. The rumor is they will have lenses designed to work with both the 2X format cameras and with an adapter work with the current format cameras. The interesting part is the camera will apparently be designed to shoot with existing EF lenses as well as the new 2X lenses, but in a crop mode. If true this would be a very cool upgrade path and would potentially compete well with Hasselblad without pissing off current Canon users. This is only a rumor, but comes from medium reliability sources so could be something Canon is thinking about or prototyping, but may not have developed. Cost will be high though.
#5 | |
hey thanks for the very detailed info.... |
#6 |
Hadn't heard about that Longwatcher
Stefan 5D, 5D, 40D + 17-40L, 24-70L, 70-200L, 50/1.4, 85/1.8, 100L Macro and some other stuff. flickr, 5∞px |
#7 |
Sir Chimp-a-lot
Two sensors, side by side you say?
Cough*bullsh*Cough
| Thread Tools | |
| Display Modes | |
| When do you think the 5D will be replaced? | Tee Why | Camera Rumors and Predictions | 12 | 1st of February 2008 (Fri) 12:17 |
| Has the 20D been replaced | mikeanywhere | Canon EOS Digital Cameras | 57 | 10th of September 2006 (Sun) 14:37 |
| My camera is been replaced | fstop11.net | Canon EOS Digital Cameras | 7 | 24th of August 2006 (Thu) 09:16 |
| Sigma replaced with new 24-70 EX!!!! | sonnyc | Canon EF and EF-S Lenses | 11 | 7th of December 2005 (Wed) 23:46 |
