Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 7th of March 2002 (Thu)   #1
jnwild
Default How to extract from old ZoomBrowser
I had an older Canon model with ZoomBrowser 1.1 -- then got a new Canon with ZoomBrowswer EX.
When I try to open any of the old databases from ZB EX, I get an error message to the effect that the database has an older format, and to update it to the new format -- but does not offer a clue as to how to do that! It also says that the change is too great for (and I quote) "the update menu item deal with". Brilliant. So I must assume it is possible, but I don't know how. I would like to know. I would think that instructions would normally follow a direction to do something unfamiliar...
It finally states that "This version of ZoomBrowser EX uses Database format 8.0, the file format is 5.0".
Of course I could just put the files into a folder and have ZB EX build a new library, but the all of the camera settings and the date the photo was taken (etc.) would not be available.
Can anyone shed some light on this issue
Thanks.
jnwild is offline   Reply With Quote
Old 18th of September 2003 (Thu)   #2
SheriG
Default Re: How to extract from old ZoomBrowser
Hello,
Well, it's months later. Did anyone ever reply to you. I just posted today and I am desperate. I have the exact same problem you did and I am terrified I will lose my images.
If you found a resolution, could you please share one. Did you lose you images?
thank you
SheriG is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ZoomBrowser update removed ZoomBrowser.exe!? pfeel Canon G-series Digital Cameras 1 6th of May 2007 (Sun) 10:21
How to extract exif data? Aquaman The POTN Lounge 5 7th of November 2006 (Tue) 08:01
extract help wanted markyb RAW, Post Processing and Printing 1 30th of December 2005 (Fri) 11:22
Extract filter Mullet RAW, Post Processing and Printing 3 28th of September 2005 (Wed) 22:51
How to extract G1 camera settings? nataatma Canon G-series Digital Cameras 2 16th of April 2002 (Tue) 20:04
