Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 19th of October 2006 (Thu)   #1
kpiela
kpiela's Avatar
Default boot thru the window
A shot of a wellie and sailor statue thru a cottage window.. does the conversion blow the it out too much?
5D Markii, 50D and 20D 70-200 f/2.8L, 50mm 1.2L Tokina 10-17, 200 f2.8, Canon 28-135mm 580ex
kpiela is offline   Reply With Quote
Old 20th of October 2006 (Fri)   #2
rab3rd
Default Re: boot thru the window
Yeah I think so, just a little. Good concept though. Keep working it.
rab3rd is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Cowgirl Boot... CM7 Still Life, B/W & Experimental 8 6th of April 2007 (Fri) 09:55
in the boot poah Transportation 15 6th of February 2007 (Tue) 21:53
Boot Camp Parkinho Still Life, B/W & Experimental 3 8th of January 2007 (Mon) 13:29
boot GyRob Still Life, B/W & Experimental 5 18th of December 2005 (Sun) 17:22
The Boot . . . RJSorensen Transportation 9 23rd of March 2005 (Wed) 20:10
