Reply
Thread Tools Display Modes
Old 20th of October 2006 (Fri)   #1
GNMink
GNMink's Avatar
Default G7 vs S3 IS vs S80...... ISO comparison
Just received my G7 today and did some quick tests with the S3 IS and the S80 for comparison.
All were done from tripod with 2sec timmer, Av mode F4 (f5.6 on S80), and ambient light.
First off a comparison of colors and contrast at ISO100
G7, Full test ISO100
S3 IS, Full test ISO100
S80, Full test ISO100
You can see ALL of the ISO test Here: http://s60.photobucket.com/albums/h2...&addtype=local
Canon G7 & SD800 IS
GNMink is offline   Reply With Quote
Old 20th of October 2006 (Fri)   #2
GNMink
GNMink's Avatar
Default Re: G7 vs S3 IS vs S80...... ISO comparison
Now Crops at ISO 100 & 200 of all three cameras
G7 ISO100
S3 IS ISO100
S80 ISO100
G7 ISO200
S3 IS ISO200
S80 ISO200
Canon G7 & SD800 IS
Old 20th of October 2006 (Fri)   #3
GNMink
GNMink's Avatar
Now ISO 400 with all three cameras, ISO 800 with the S3 IS and G7, and finally ISO 1600 with the G7
G7 ISO 400
S3 IS ISO400
S80 ISO400
G7 ISO800
S3 IS ISO800
G7 ISO1600
Canon G7 & SD800 IS
Old 20th of October 2006 (Fri)   #4
GNMink
GNMink's Avatar
I'm very impressed with the G7, its built very nice and the new Digic III is fast. Some improvments in the menu system too.
It's very solid feeling and is mainly metal, with only the battery, ports, and top panel made from plastic. Even the top control knobs are metal. Its slightly larger than the S80, but still very compact.
Canon G7 & SD800 IS
Old 20th of October 2006 (Fri)   #5
photography By Evangelos
photography By Evangelos's Avatar
Look way cool for such a small camera. My things have improved over the past few years.
Angelo
photography By Evangelos is offline   Reply With Quote
Old 21st of October 2006 (Sat)   #6
RafaPolit
RafaPolit's Avatar
Thanks GNMink, very useful comparison!!
It does a lot for me in several aspects... first, I see that any of this cameras from canon will produce the same result if resized to 800x600, so if web is your final destination, probably more money wouldnt get better pictures.
But, the 100% crops show clearly the increased MegaPixels of the G7, therefore a bigger piece of the image, with less noise (apparently through in-camera noise reduction from the pattern of noise) than that of its rivals. And even though the ISO1600 is very noisy, I believe its comparable to the ISO400 of my fathers Pro1, so you have 2 more f/stops to play with light!
Can you comment about the IS? How is the filling of that? How about the other features? bigger LCD? How is the Optical Viewfinder? How about autofocus in low light? and speed of focus?
Thanks again for the scoup of the G7, you will surely receive tons of questions. Thanks truly,
Rafa Polit Jr.
RafaPolit is offline   Reply With Quote
Old 22nd of October 2006 (Sun)   #7
Ballen Photo
Moderator
Ballen Photo's Avatar
A very nice comparison of these three cameras. Thank You!
-Bruce
The Captain and crew finally got their stuff together, now if we can only remember where we left it.
Ballen Photo is offline   Reply With Quote
Old 23rd of October 2006 (Mon)   #8
mattjs
Nice to hear you think it's fast. Would you say noticeably quicker than the S3? Also, how about the LCD? It's described as "wide angle view". Is there a noticeable advantage versus a standard LCD in terms of viewing at angles? I know it's kind of gimmicky, but have you goofed around with the facial recognition focus feature? Any thoughts on battery life yet?
mattjs is offline   Reply With Quote
Old 23rd of October 2006 (Mon)   #9
GNMink
GNMink's Avatar
It starts up very fast, and focus is very quick and accurate. Not sure if its faster than the S3, my hunch is that it focus is just a little quicker.
The LCD is very bright and seems to be viewable at all angles. One big surprise is the optical rangefinder, its clearer than I figured it would be and is pretty accurate when zoomed altho its only 80% view but definetly usable in condtions that the LCD is not readable.
The face recognition feature works! works very well indeed. The subject has to be looking towards the camera for it to recongize the face but tracks very well and can recongize several faces (max of 9)
I like the camera alot, it has much to offer. I think G3, G5, and G6 users looking to upgrade will be disapointed in the size and ergonomics (lack of a grip) and will probably miss the tilt/swivel LCD. But Image quality is very good and the camera certainly isn't missing any controls/features and the IS is a big plus.
Obviously the G7 is not really a continuation of the G series, its a whole new design as an advanced compact. I think its the best compact camera out right now. I've heard alot of talk about the ISO 1600 performace but atleast it has the ability to "get" the shot and IMO ISO 1600 is as good as it gets right now with such a small sensor (Fuji F30 excluded! LOL)
Obviously Canon has decided that the 400D is priced agressively enough now that it would appeal to G series users looking for something new.
The S3 IS has everything you could want and is priced $200 less than the G7 so its a tough call between the two.
Canon G7 & SD800 IS
Old 23rd of October 2006 (Mon)   #10
mattjs
I'm gonna wait and see what the G7 reviews look like, but this is a huge help, and thanks for posting the samples. Based on what I see in the samples I'm deffinitely still considering the G7.
With the smaller grip, does it feel secure holding it with one hand (something I often do between shots with the G3).
Old 23rd of October 2006 (Mon)   #11
GNMink
GNMink's Avatar
I'd used the supplied neck strap! LOL
Canon G7 & SD800 IS
Old 23rd of October 2006 (Mon)   #12
mattjs
Thanks. That's what I figured. It looks pretty small (both the overall and the grip). Overall smallness will be a plus to me. The easier it is to take it places the better.
Old 23rd of October 2006 (Mon)   #13
lefturn99
lefturn99's Avatar
Thanks for the comparison. Wonder what the 400 and 800 shots would look like after a pass through NeatImage?
5D Mk II, 40D, G9, 10-22, 17-40, 24-105 IS, 17-85 IS, 50mm 1.8, 100 2.8, 70-200 2.8 IS, 100-400, 580ex II (x3), Sunpak 383 (x3), Skyports
lefturn99 is online now   Reply With Quote
Old 22nd of November 2006 (Wed)   #14
w7ox
Thanks for the comparative tests. Having the S3 IS, I was surprised it held up as well as it did at ISO 400 .. not up to the G7, but not *far* worse. With an SD700IS, great for "go anywhere", and the S3 IS (plus a 20D and lenses if I want to lug stuff), I will likely pass on the G7. It definitely has better IQ than the S3, but there is no niche between the SD700 and S3 where it can fit.
Phil
w7ox is offline   Reply With Quote
Old 25th of November 2006 (Sat)   #15
Azzure_7
Azzure_7's Avatar
Thanks for the comparison. . .
It helps me . . .but in the end, which one is the best catch?
http://photography-on-the.net/forum/...=1#post2310420
Azzure_7 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SD700IS, SD800IS, and G7.......ISO Comparison GNMink Small Compact Digitals by Canon 5 8th of January 2007 (Mon) 02:26
30D High vs Low ISO comparison EOSAddict Canon EOS Digital Cameras 5 22nd of March 2006 (Wed) 17:53
High ISO comparison 1D Mk II & Rebel XT Tom W Canon EOS Digital Cameras 21 15th of July 2005 (Fri) 14:44
XT 350D ISO Comparison with kit lens guitarman3 Canon EOS Digital Cameras 4 3rd of April 2005 (Sun) 12:08
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
